[MOAB-dev] r5141 - MOAB/trunk/test/obb
Iulian Grindeanu
iulian at mcs.anl.gov
Tue Aug 30 16:36:06 CDT 2011
I think that h5portable has the same issue?
$ h5portable
Running test_native_read ...
Attempting to use an MPI routine after finalizing MPICH
----- Original Message -----
> Author: kraftche
> Date: 2011-08-30 16:30:00 -0500 (Tue, 30 Aug 2011)
> New Revision: 5141
> Modified:
> MOAB/trunk/test/obb/Makefile.am
> MOAB/trunk/test/obb/obb_test.cpp
> Log:
> yet another test that needs to call MPI_Init and MPI_Finalize even
> though it doesn't do anything parallel
> Modified: MOAB/trunk/test/obb/Makefile.am
> --- MOAB/trunk/test/obb/Makefile.am 2011-08-30 18:14:08 UTC (rev 5140)
> +++ MOAB/trunk/test/obb/Makefile.am 2011-08-30 21:30:00 UTC (rev 5141)
> @@ -5,7 +5,8 @@
> AM_CPPFLAGS += -DSRCDIR=$(srcdir) \
> -DMESHDIR=$(MESHDIR) \
> - -I$(top_srcdir)/src -I$(top_builddir)/src -I..
> + -I$(top_srcdir)/src -I$(top_builddir)/src -I.. \
> + -I$(top_srcdir)/src/parallel -I$(top_builddir)/src/parallel
> LDADD = $(top_builddir)/src/libMOAB.la
> Modified: MOAB/trunk/test/obb/obb_test.cpp
> --- MOAB/trunk/test/obb/obb_test.cpp 2011-08-30 18:14:08 UTC (rev
> 5140)
> +++ MOAB/trunk/test/obb/obb_test.cpp 2011-08-30 21:30:00 UTC (rev
> 5141)
> @@ -6,6 +6,10 @@
> #include "moab/GeomUtil.hpp"
> #include "moab/CN.hpp"
> +#ifdef USE_MPI
> +#include "moab_mpi.h"
> +#endif
> #include <iostream>
> #include <sstream>
> #include <stdlib.h>
> @@ -119,6 +123,11 @@
> int main( int argc, char* argv[] )
> +#ifdef USE_MPI
> + int fail = MPI_Init(&argc, &argv);
> + if (fail) return fail;
> +#endif
> std::vector<const char*> file_names;
> bool flags = true;
> for (int i = 1; i < argc; ++i) {
> @@ -204,6 +213,11 @@
> for (unsigned j = 0; j < file_names.size(); ++j)
> if (!do_file( file_names[j] ))
> ++exit_val;
> +#ifdef USE_MPI
> + fail = MPI_Finalize();
> +#endif
