[MOAB-dev] r5116 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu
Thu Aug 25 11:59:16 CDT 2011
Author: kraftche
Date: 2011-08-25 11:59:16 -0500 (Thu, 25 Aug 2011)
New Revision: 5116
Modified:
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
Log:
fix warning and add some comments to parallel HDF5 writer
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2011-08-25 16:38:50 UTC (rev 5115)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2011-08-25 16:59:16 UTC (rev 5116)
@@ -1042,18 +1042,28 @@
total_entities[index] = cumulative[index].total;
- // calculate per-processor offsets
+ // convert array of per-process counts to per-process offsets
if (rank == 0)
+ // initialize prev_size with data sizes for root process
std::vector<long> prev_size(counts.begin(), counts.begin() + num_datasets);
+ // root process gets offset zero
std::fill( counts.begin(), counts.begin() + num_datasets, 0L );
+ // for each proc other than this one (root)
for (unsigned i = 1; i < nproc; ++i)
+ // get pointer to offsets for previous process in list
long* prev_data = &counts[(i-1)*num_datasets];
+ // get poitner to offsets for this process in list
long* proc_data = &counts[i*num_datasets];
+ // for each data set
for (int j = 0; j < num_datasets; ++j) {
+ // get size of data in dataset from process i
long mysize = proc_data[j];
+ // offset for process i is offset of prevous process plus
+ // number of values previous process will write
proc_data[j] = prev_data[j] + prev_size[j];
+ // store my size, as it is no longer available in 'counts'
prev_size[j] = mysize;
@@ -1640,7 +1650,7 @@
size_t old_size = tmp.size();
tmp.resize( sizeof(long) * old_size / sizeof(id_t) );
unsigned long* array = reinterpret_cast<unsigned long*>(&tmp[0]);
- for (size_t i = old_size-1; i >= 0; --i)
+ for (long i = ((long)old_size)-1; i >= 0; --i)
array[i] = tmp[i];
contents = array;
