[MOAB-dev] r5115 - MOAB/trunk/src/parallel
tautges at mcs.anl.gov
Thu Aug 25 11:38:51 CDT 2011
Author: tautges
Date: 2011-08-25 11:38:50 -0500 (Thu, 25 Aug 2011)
New Revision: 5115
Modified:
MOAB/trunk/src/parallel/ParallelComm.cpp
Log:
For resolving shared sets, neglect sets that don't have a global id.
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-08-25 15:15:36 UTC (rev 5114)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-08-25 16:38:50 UTC (rev 5115)
@@ -3843,25 +3843,23 @@
// build sharing list for all sets
// get ids for sets in a vector, to pass to gs
- const size_t nsets = sets.size();
- std::vector<long> larray(nsets); // allocate sufficient space for longs
- int* ids = reinterpret_cast<int*>(&larray[0]); // but work with ints
- result = mbImpl->tag_get_data(idtag, sets, ids);
- RRA("Couldn't get global ids for sets.");
- // convert from int to long if necessary
- if (sizeof(long) > sizeof(int)) {
- size_t i = nsets;
- while (i) {
- --i;
- larray[i] = ids[i];
+ std::vector<long> larray; // allocate sufficient space for longs
+ std::vector<unsigned long> handles;
+ Range tmp_sets;
+ for (Range::iterator rit = sets.begin(); rit != sets.end(); rit++) {
+ int dum;
+ result = mbImpl->tag_get_data(idtag, &(*rit), 1, &dum);
+ if (MB_SUCCESS == result) {
+ larray.push_back(dum);
+ handles.push_back(*rit);
+ tmp_sets.insert(tmp_sets.end(), *rit);
+ const size_t nsets = handles.size();
// get handle array for sets
assert(sizeof(EntityHandle) <= sizeof(unsigned long));
- std::vector<unsigned long> handles(nsets);
- std::copy( sets.begin(), sets.end(), handles.begin() );
// do communication of data
crystal_data *cd = procConfig.crystal_router();
@@ -3900,8 +3898,8 @@
size_t ti = 0;
unsigned idx = 0;
std::vector<unsigned> procs;
- Range::iterator si = sets.begin();
- while (si != sets.end() && ti < tuples.size()) {
+ Range::iterator si = tmp_sets.begin();
+ while (si != tmp_sets.end() && ti < tuples.size()) {
assert(idx <= tuples[ti].idx);
