[MOAB-dev] GLOBAL_ID = 0 in parallel writer
Tim Tautges
tautges at mcs.anl.gov
Fri Aug 5 13:58:00 CDT 2011
On 08/05/2011 12:37 PM, Hong-Jun Kim wrote:
> Currently, parallel writer returns error if there is no set with non-zero GLOBAL_ID tag, isn't it a bug?
Probably.
> And, should I assign the same GLOBAL_IDs to shared sets to use parallel writing?
> Doesn't it use "shared_handle/procs" tag information?
That code is in the process of being rewritten. Currently, it tries to match sets with like values for some specific
tags (MATERIAL_SET, NEUMANN/DIRICHLET sets).
- tim
> Hong-Jun
>> Probably it's just that the global id hasn't been initialized for
>> those sets.
>> - tim
>> On 08/05/2011 11:28 AM, Hong-Jun Kim wrote:
>>> Hi, all
>>> I have a problem to use parallel write in hdf5 format.
>>> It looks finding all sets with GEOMETRIC_DIMENSION tag and GLOBAL_ID
>>> = 0 and removing from export list.
>>> So, I am wondering what GLOBAL_ID = 0 means.
>>> Does it mean any special meaning in parallel writer?
>>> Thanks.
>>> Hong-Jun Kim
>>> Post-doc researcher
>>> MCS, Argonne National Laboratory
>>> 9700 S. Cass Ave. B240/R2147
>>> Argonne, IL 60439
>>> 630-252-4791
>>> hongjun at mcs.anl.gov
>> "You will keep in perfect peace him whose mind is
>> steadfast, because he trusts in you." Isaiah 26:3
>> Tim Tautges Argonne National Laboratory
>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>> phone: (608) 263-8485 1500 Engineering Dr.
>> fax: (608) 263-4499 Madison, WI 53706
