[MOAB-dev] GLOBAL_ID = 0 in parallel writer
Hong-Jun Kim hongjun at mcs.anl.gov
Fri Aug 5 12:37:44 CDT 2011
Currently, parallel writer returns error if there is no set with non-zero GLOBAL_ID tag, isn't it a bug?
And, should I assign the same GLOBAL_IDs to shared sets to use parallel writing?
Doesn't it use "shared_handle/procs" tag information?
Hong-Jun
> Probably it's just that the global id hasn't been initialized for
> those sets.
> - tim
> On 08/05/2011 11:28 AM, Hong-Jun Kim wrote:
> > Hi, all
> > I have a problem to use parallel write in hdf5 format.
> > It looks finding all sets with GEOMETRIC_DIMENSION tag and GLOBAL_ID
> > = 0 and removing from export list.
> > So, I am wondering what GLOBAL_ID = 0 means.
> > Does it mean any special meaning in parallel writer?
> > Thanks.
> > Hong-Jun Kim
> > Post-doc researcher
> > MCS, Argonne National Laboratory
> > 9700 S. Cass Ave. B240/R2147
> > Argonne, IL 60439
> > 630-252-4791
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
