[MOAB-dev] r5083 - MOAB/trunk/itaps
tautges at mcs.anl.gov
Fri Aug 5 11:00:39 CDT 2011
Author: tautges
Date: 2011-08-05 11:00:38 -0500 (Fri, 05 Aug 2011)
New Revision: 5083
Modified:
MOAB/trunk/itaps/iBase_f.h
Log:
Changing some of the parameters corresponding to tag data type,
which were out of synch with .h file versions.
Modified: MOAB/trunk/itaps/iBase_f.h
--- MOAB/trunk/itaps/iBase_f.h 2011-08-04 18:07:50 UTC (rev 5082)
+++ MOAB/trunk/itaps/iBase_f.h 2011-08-05 16:00:38 UTC (rev 5083)
@@ -102,10 +102,12 @@
integer iBase_INTEGER
integer iBase_DOUBLE
integer iBase_ENTITY_HANDLE
+ integer iBase_ENTITY_SET_HANDLE
integer iBase_BYTES
- parameter (iBase_INTEGER = 0)
- parameter (iBase_DOUBLE = 1)
- parameter (iBase_ENTITY_HANDLE = 2)
- parameter (iBase_BYTES = 3)
+ parameter (iBase_BYTES = 0)
+ parameter (iBase_INTEGER = 1)
+ parameter (iBase_DOUBLE = 2)
+ parameter (iBase_ENTITY_HANDLE = 3)
+ parameter (iBase_ENTITY_SET_HANDLE = 3)
