[MOAB-dev] iMeshP function argument
Tim Tautges
tautges at mcs.anl.gov
Thu Jun 16 10:57:09 CDT 2011
[also cc'ing itaps-dev...]
On 06/16/2011 10:48 AM, Hong-Jun Kim wrote:
> I have one more question about the argument, command_code, as in the
> following function.
> void iMeshP_exchEntArrToPartsAll(
> iMesh_Instance instance,
> const iMeshP_PartitionHandle partition,
> const iBase_EntityHandle *entities,
> const int entities_size,
> const iMeshP_Part *target_part_ids,
> int command_code,
> int update_ghost,
> iMeshP_RequestHandle *request,
> int *err);
> The command_code is indicating whether to migrate input entities or only
> makes copies, that is, the ownership should be changed if it is set as 1.
> However, this option can make some questions to me.
> At first, if the entities are migrated to another processor, should the
> entities be deleted in sending processor?
I don't think so.
> In addition, if there are already shared information in entities or the
> exchanged entities are multi-shared, I can not decide which processor
> has the ownership.
> For example, if the entity is shared by p0, p1 and p2 and they are sent
> from p0 to p1 and p2, which processor should have the ownership?
> And, if the entity's ownership is already got from p0, when the entity
> is sent from p1 to only p2, the entity's ownership is changed to p2 in
> p1 and p2, and should the ownership in p0 also be changed to p2?
Good questions. I think RPI is the only institution who's implemented this function so far, so maybe they can comment?
- tim
> I think there can be more problems to me when command_code is set to 1,
> and then can you give me some comments about it not to wander about the
> function?
> Thanks.
> Hong-Jun
> > From: "Tim Tautges" <tautges at mcs.anl.gov>
> > To: moab-dev at mcs.anl.gov
> > Sent: Wednesday, June 15, 2011 3:07:36 PM
> > Subject: Re: [MOAB-dev] iMeshP function argument
> > I think in this case the number of part ids is the same as the number
> > of entities.
> > - tim
> > On 06/14/2011 02:20 PM, Hong-Jun Kim wrote:
> > > Hi, all
> > > I am implementing the following function in iMeshP, but I just want
> > > to
> > > confirm "const iMeshP_Part *target_part_ids" argument is correct.
> > > I think it should be "const iMeshP_Part target_part_ids" for one
> > > input
> > > part, or for multiple input parts, there should be one more "const
> > > int
> > > part_id_size" argument.
> > > Isn't it right?
> > > int command_code,
> > > int update_ghost,
> > > int *err);
> > > Hong-Jun Kim
> > > Post-doc researcher
> > > MCS, Argonne National Laboratory
> > > 9700 S. Cass Ave. B240/R2147
> > > Argonne, IL 60439
> > > 630-252-4791
> > > hongjun at mcs.anl.gov
> > "You will keep in perfect peace him whose mind is
> > steadfast, because he trusts in you." Isaiah 26:3
> > Tim Tautges Argonne National Laboratory
> > (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> > phone: (608) 263-8485 1500 Engineering Dr.
> > fax: (608) 263-4499 Madison, WI 53706
