[MOAB-dev] r4991 - in MOAB/trunk: src tools/dagmc
sjackson at cae.wisc.edu
Mon Jun 13 16:36:48 CDT 2011
Author: sjackson
Date: 2011-06-13 16:36:47 -0500 (Mon, 13 Jun 2011)
New Revision: 4991
Modified:
MOAB/trunk/src/GeomTopoTool.cpp
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/test_geom.cc
Log:
Fix a bug that prevented DagMC from loading .sat files
Because GeomTopoTool sets a default value for the GEOM_SENSE_2 tag,
DagMC needs to look up the handle for that tag after file loading
is finished to prevent a default value conflict. All tag handle
lookups done by DagMC are moved after the file loading phase,
which is a somewhat more logical time to perform them anyway.
Modify GeomTopoTool.cpp to return detailed error values instead of
MB_FAILURE in places where such values are already available.
Modified: MOAB/trunk/src/GeomTopoTool.cpp
--- MOAB/trunk/src/GeomTopoTool.cpp 2011-06-13 20:51:27 UTC (rev 4990)
+++ MOAB/trunk/src/GeomTopoTool.cpp 2011-06-13 21:36:47 UTC (rev 4991)
@@ -263,7 +263,9 @@
trees.clear();
for (Range::iterator j = tmp_surfs.begin(); j != tmp_surfs.end(); ++j) {
rval = get_root(*j, root);
- if (MB_SUCCESS != rval || !root)
+ if (MB_SUCCESS != rval )
+ return rval;
+ if(!root)
return MB_FAILURE;
trees.insert(root);
@@ -578,7 +580,7 @@
EntityHandle sense_data[2] = { 0, 0 };
rval = mdbImpl->tag_get_data(sense2Tag, &entity, 1, sense_data);
if (MB_TAG_NOT_FOUND != rval && MB_SUCCESS != rval)
- return MB_FAILURE;
+ return rval;
if (0 == sense) {
if (0 != sense_data[0] && wrt_entity != sense_data[0])
@@ -645,7 +647,7 @@
+ return rval;
if ((wrt_entity == sense_data[0]) && (wrt_entity == sense_data[1]))
sense = 0;
else if (wrt_entity == sense_data[0])
@@ -766,7 +768,7 @@
rval = mdbImpl->tag_get_handle(GEOM_SENSE_2_TAG_NAME, 2,
MB_TYPE_HANDLE, sense2Tag, flags, def_val);
if (MB_SUCCESS != rval)
+ return rval;
return MB_SUCCESS;
@@ -781,11 +783,11 @@
rval = mdbImpl->tag_get_handle(GEOM_SENSE_N_ENTS_TAG_NAME,
0, MB_TYPE_HANDLE, senseNEntsTag, flags);
+ return rval;
rval = mdbImpl->tag_get_handle(GEOM_SENSE_N_SENSES_TAG_NAME,
0, MB_TYPE_INTEGER, senseNSensesTag, flags);
