[MOAB-dev] r4971 - in MOAB/trunk: . src/io test/io
tautges at mcs.anl.gov
Wed Jun 8 12:56:29 CDT 2011
Author: tautges
Date: 2011-06-08 12:56:28 -0500 (Wed, 08 Jun 2011)
New Revision: 4971
Modified:
MOAB/trunk/moab.make.in
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/src/io/ReadNC.hpp
MOAB/trunk/test/io/read_nc.cpp
Log:
Implement the ability to not read any variables from an NC file (accessed using "VARIABLE=" option, where
no variable names are specified).
Also, removing the duplicate CGM_LIBS argument I'd put in earlier today.
Modified: MOAB/trunk/moab.make.in
--- MOAB/trunk/moab.make.in 2011-06-08 17:54:06 UTC (rev 4970)
+++ MOAB/trunk/moab.make.in 2011-06-08 17:56:28 UTC (rev 4971)
@@ -12,7 +12,7 @@
MOAB_CFLAGS = @CFLAGS@ @AM_CFLAGS@
MOAB_LDFLAGS = @EXPORT_LDFLAGS@
-MOAB_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR} -lMOAB @LIBS@ @CGM_LIBS@ @PNETCDF_LIBS@ @NETCDF_LIBS@ @HDF5_LIBS@ @CCMIO_LIBS@ @CGM_LIBS@
+MOAB_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR} -lMOAB @LIBS@ @PNETCDF_LIBS@ @NETCDF_LIBS@ @HDF5_LIBS@ @CCMIO_LIBS@ @CGM_LIBS@
# Override MOAB_LIBDIR and MOAB_INCLUDES from above with the correct
# values for the installed MOAB.
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2011-06-08 17:54:06 UTC (rev 4970)
+++ MOAB/trunk/src/io/ReadNC.cpp 2011-06-08 17:56:28 UTC (rev 4971)
@@ -98,9 +98,9 @@
return rval;
- bool nomesh = false;
+ bool nomesh = false, novars = false;
std::string partition_tag_name;
- rval = parse_options(opts, var_names, tstep_nums, tstep_vals, nomesh, partition_tag_name);
+ rval = parse_options(opts, var_names, tstep_nums, tstep_vals, nomesh, novars, partition_tag_name);
ERRORR(rval, "Trouble parsing option string.");
// Open the file
@@ -139,19 +139,21 @@
// Create structured mesh vertex/hex sequences
Range hexes;
- if (nomesh) {
+ if (nomesh && !novars) {
rval = check_verts_hexes(tmp_set);
ERRORR(rval, "Mesh characteristics didn't match from last read.\n");
- else {
+ else if (!nomesh) {
rval = create_verts_hexes(tmp_set, hexes);
ERRORR(rval, "Trouble creating vertices.");
// Read variables onto grid
- rval = read_variables(tmp_set, var_names, tstep_nums, nomesh);
- if (MB_FAILURE == rval) return rval;
+ if (!novars) {
+ rval = read_variables(tmp_set, var_names, tstep_nums);
