[MOAB-dev] r4970 - MOAB/trunk/src/parallel
tautges at mcs.anl.gov
Wed Jun 8 12:54:07 CDT 2011
Author: tautges
Date: 2011-06-08 12:54:06 -0500 (Wed, 08 Jun 2011)
New Revision: 4970
Modified:
MOAB/trunk/src/parallel/ReadParallel.cpp
Log:
Change parallel read to not create a new entity set if a file set was
passed in.
Modified: MOAB/trunk/src/parallel/ReadParallel.cpp
--- MOAB/trunk/src/parallel/ReadParallel.cpp 2011-06-08 16:20:11 UTC (rev 4969)
+++ MOAB/trunk/src/parallel/ReadParallel.cpp 2011-06-08 17:54:06 UTC (rev 4970)
@@ -280,8 +280,11 @@
// make a new set for the parallel read
EntityHandle file_set;
- result = mbImpl->create_meshset(MESHSET_SET, file_set);
- if (MB_SUCCESS != result) return result;
+ if (!file_set_ptr || !(*file_set_ptr)) {
+ result = mbImpl->create_meshset(MESHSET_SET, file_set);
+ if (MB_SUCCESS != result) return result;
+ else file_set = *file_set_ptr;
bool i_read = false;
Tag id_tag = 0;
@@ -534,13 +537,15 @@
std::cout << " " << act_times[0] << " PARALLEL TOTAL" << std::endl;
if (MB_SUCCESS == result && file_set_ptr) {
Range all_ents;
result = mbImpl->get_entities_by_handle(file_set, all_ents);
if (MB_SUCCESS == result)
result = mbImpl->add_entities(*file_set_ptr, all_ents);
return result;
