[MOAB-dev] r4958 - in MOAB/trunk: src test
iulian at mcs.anl.gov
Mon Jun 6 17:25:07 CDT 2011
Author: iulian
Date: 2011-06-06 17:25:06 -0500 (Mon, 06 Jun 2011)
New Revision: 4958
Modified:
MOAB/trunk/src/FBEngine.cpp
MOAB/trunk/test/mbfacet_test.cpp
Log:
control face points were not deleted, not sure why
also, modify the test/tool so it allows just cropping, it stops after
writing the file with the cropped boundary
Modified: MOAB/trunk/src/FBEngine.cpp
--- MOAB/trunk/src/FBEngine.cpp 2011-06-06 19:33:35 UTC (rev 4957)
+++ MOAB/trunk/src/FBEngine.cpp 2011-06-06 22:25:06 UTC (rev 4958)
@@ -392,13 +392,13 @@
if (rval != MB_TAG_NOT_FOUND)
smoothTags.push_back(tag_handle);
- rval = _mbImpl->tag_get_handle( "CONTROLEDGE", 18, MB_TYPE_DOUBLE, tag_handle );
+ rval = _mbImpl->tag_get_handle( "CONTROLEDGE", 9, MB_TYPE_DOUBLE, tag_handle );
- //rval = _mbImpl->tag_get_handle( "CONTROLFACE", 0, MB_TYPE_DOUBLE, tag_handle );
- //if (rval != MB_TAG_NOT_FOUND)
- // smoothTags.push_back(tag_handle);
+ rval = _mbImpl->tag_get_handle( "CONTROLFACE", 18, MB_TYPE_DOUBLE, tag_handle );
+ if (rval != MB_TAG_NOT_FOUND)
+ smoothTags.push_back(tag_handle);
rval = _mbImpl->tag_get_handle( "CONTROLEDGEFACE", 27, MB_TYPE_DOUBLE, tag_handle );
Modified: MOAB/trunk/test/mbfacet_test.cpp
--- MOAB/trunk/test/mbfacet_test.cpp 2011-06-06 19:33:35 UTC (rev 4957)
+++ MOAB/trunk/test/mbfacet_test.cpp 2011-06-06 22:25:06 UTC (rev 4958)
@@ -87,12 +87,16 @@
quads_file = TestDir + "/quads.h5m";
keep_output = false;
+ bool only_cropping = false;
if (argc == 1) {
std::cout << "Using default input files: " << filename << " " << polygon_file_name <<
- " " << std::endl;
+ " " << filename_out << " " << quads_file << std::endl;
std::cout << " default output file: " << filename_out << " will be deleted \n";
- std::cout << " quads test file: " << quads_file << "\n";
+ } else if (argc == 4) {
+ only_cropping = true;
+ filename = argv[1];
+ polygon_file_name = argv[2];
+ filename_out = argv[3];
} else if (argc >=5) {
filename = argv[1];
@@ -159,6 +163,8 @@
handle_error_code(rval, number_tests_failed, number_tests_successful);
std::cout << "\n";
