[MOAB-dev] r4957 - MOAB/trunk/src/moab
kraftche at cae.wisc.edu
Mon Jun 6 14:33:36 CDT 2011
Author: kraftche
Date: 2011-06-06 14:33:35 -0500 (Mon, 06 Jun 2011)
New Revision: 4957
Modified:
MOAB/trunk/src/moab/Core.hpp
MOAB/trunk/src/moab/Interface.hpp
Log:
document deprecated tag functions
Modified: MOAB/trunk/src/moab/Core.hpp
--- MOAB/trunk/src/moab/Core.hpp 2011-06-06 19:32:06 UTC (rev 4956)
+++ MOAB/trunk/src/moab/Core.hpp 2011-06-06 19:33:35 UTC (rev 4957)
@@ -649,10 +649,13 @@
virtual ErrorCode tag_get_name(const Tag tag_handle,
std::string& tag_name) const;
- //! Gets the tag handle corresponding to a name
- /** If a tag of that name does not exist, returns MB_TAG_NOT_FOUND
- \param tag_name Name of the desired tag.
- \param tag_handle Tag handle corresponding to <em>tag_name</em>
+ /**\brief Gets the tag handle corresponding to a name
+ *\deprecated Use tag_get_handle instead
+ * If a tag of that name does not exist, returns MB_TAG_NOT_FOUND
+ * \param tag_name Name of the desired tag.
+ * \param tag_handle Tag handle corresponding to <em>tag_name</em>
virtual ErrorCode tag_get_handle( const char *tag_name,
Tag &tag_handle ) const MB_DEPRECATED;
@@ -661,7 +664,10 @@
virtual ErrorCode tag_get_tags_on_entity(const EntityHandle entity,
std::vector<Tag> &tag_handles) const;
- //! get size of tag in bytes
+ /**\brief get size of tag in bytes
+ *\deprecated Use tag_get_bytes or tag_get_length instead
virtual ErrorCode tag_get_size(const Tag tag, int &tag_size) const MB_DEPRECATED;
//! Get the size of the specified tag in bytes
@@ -723,16 +729,7 @@
/**\brief Get pointers to tag data
- * For a tag, get the values for a list of passed entity handles.
- *\param tag_handle The tag
- *\param entity_handles An array of entity handles for which to retreive tag values.
- *\param num_entities The length of the 'entity_handles' array.
- *\param tag_data An array of 'const void*'. Array must be at least
- * 'num_entitities' long. Array is populated (output)
- * with pointers to the internal storage for the
- * tag value corresponding to each entity handle.
- *\param tag_sizes The length of each tag value. Optional for
- * fixed-length tags. Required for variable-length tags.
+ *\deprecated Use tag_get_by_ptr instead.
virtual ErrorCode tag_get_data(const Tag tag_handle,
