[MOAB-dev] r4951 - MOAB/trunk/src/io
xbxu at mcs.anl.gov
xbxu at mcs.anl.gov
Mon Jun 6 13:04:14 CDT 2011
Author: xbxu
Date: 2011-06-06 13:04:13 -0500 (Mon, 06 Jun 2011)
New Revision: 4951
Modified:
MOAB/trunk/src/io/ReadNC.cpp
Log:
only create dim_name tag for lon,lat,lev,time
only create __<dim_name>_LOC_VALS tag for time
__<var_name>_DIMS created for variables having at least one dimension.
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2011-06-06 17:42:25 UTC (rev 4950)
+++ MOAB/trunk/src/io/ReadNC.cpp 2011-06-06 18:04:13 UTC (rev 4951)
@@ -1228,10 +1228,7 @@
dimNamesSz = dimNames.size();
for (unsigned int i = 0; i != dimNamesSz; ++i) {
tag_name = dimNames[i];
- Tag tagh = 0;
- DataType data_type;
void * val = NULL;
- int val_len = 0;
if (tag_name == "lon")
val = &ilVals[0];
else if (tag_name == "lat")
@@ -1241,22 +1238,20 @@
else if (tag_name == "time")
val = &tVals[0];
else {
- std::string s = "Unrecognized dimension name";
- s += tag_name;
- s += "\n";
- ERRORR(MB_FAILURE, s.c_str());
+ continue;
+ Tag tagh = 0;
+ DataType data_type;
+ int val_len = dimVals[i];
switch (varInfo[tag_name].varDataType) {
case NC_BYTE:
case NC_CHAR:
case NC_DOUBLE:
data_type = MB_TYPE_DOUBLE;
- val_len = sizeof(double) * dimVals[i];
break;
case NC_FLOAT:
case NC_INT:
data_type = MB_TYPE_INTEGER;
- val_len = sizeof(int) * dimVals[i];
break;
case NC_SHORT:
default:
@@ -1300,25 +1295,16 @@
// __<dim_name>_LOC_VALS
- if (dimNames[i] != "lon" && dimNames[i] != "lat" && dimNames[i] != "lev") {
- Tag tagh = 0;
- std::vector<int> val;
- if (dimNames[i] == "time") {
- val = tstep_nums;
