[MOAB-dev] r4949 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Mon Jun 6 11:42:47 CDT 2011
Author: kraftche
Date: 2011-06-06 11:42:46 -0500 (Mon, 06 Jun 2011)
New Revision: 4949
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
Log:
fix bug in seldom-used code path of ReadHDF5 that will cause failures with some versions of HDF5 library
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2011-06-06 15:12:57 UTC (rev 4948)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-06-06 16:42:46 UTC (rev 4949)
@@ -3853,8 +3853,6 @@
if (MB_SUCCESS != rval)
return error(rval);
- CHECK_OPEN_HANDLES;
int tag_index;
rval = find_int_tag( tag_name, tag_index );
if (MB_SUCCESS != rval) {
