[MOAB-dev] r4936 - MOAB/trunk/src/parallel
Hong-Jun Kim
hongjun at mcs.anl.gov
Fri Jun 3 13:35:07 CDT 2011
You are right.
It sets default value in MOAB but not in MeshKit.
I changed not giving all default values.
Thanks for your help.
Hong-Jun
----- Original Message -----
> From: "Jason Kraftcheck" <kraftche at cae.wisc.edu>
> To: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
> Cc: moab-dev at mcs.anl.gov
> Sent: Friday, June 3, 2011 10:45:54 AM
> Subject: Re: [MOAB-dev] r4936 - MOAB/trunk/src/parallel
> On 06/03/2011 10:38 AM, Hong-Jun Kim wrote:
> >> You can use whichever you want. MOAB uses MB_TAG_EXCL to get the
> >> expected
> >> behavior for the iMesh call. But my comment was with regards to the
> >> code
> >> you changed in ParallelComm, which did not use the iMesh call.
> > Ah, I think I'd better add "MB_TAG_EXCL" to my code in ParallelComm.
> > Is it right?
> No. I think you should probably change the code back to the way it
> was.
> There is no reason to check for MB_ALREADY_ALLOCATED. Which is why I'm
> trying to understand why you added that check. Was there some error
> that
> you were fixing?
> - jason
