[MOAB-dev] r4937 - MOAB/trunk/src/io
jain at mcs.anl.gov
jain at mcs.anl.gov
Thu Jun 2 20:26:24 CDT 2011
Author: jain
Date: 2011-06-02 20:26:24 -0500 (Thu, 02 Jun 2011)
New Revision: 4937
Modified:
MOAB/trunk/src/io/ReadCCMIO.cpp
MOAB/trunk/src/io/WriteCCMIO.cpp
Log:
o Fix typos in new get_tag_handle function causing compile errors.
Modified: MOAB/trunk/src/io/ReadCCMIO.cpp
--- MOAB/trunk/src/io/ReadCCMIO.cpp 2011-06-03 00:50:28 UTC (rev 4936)
+++ MOAB/trunk/src/io/ReadCCMIO.cpp 2011-06-03 01:26:24 UTC (rev 4937)
@@ -105,7 +105,7 @@
mNeumannSetTag, MB_TAG_CREAT|MB_TAG_SPARSE);
result = impl->tag_get_handle(HAS_MID_NODES_TAG_NAME, 4, MB_TYPE_INTEGER,
- mHasMidNodesTag, MB_TAG_CREAT|MB_TAG_SPASRE );
+ mHasMidNodesTag, MB_TAG_CREAT|MB_TAG_SPARSE );
assert(MB_SUCCESS == result);
result = impl->tag_get_handle(GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER,
@@ -314,7 +314,7 @@
if (kCCMIONoErr == CCMIOReadOpti(NULL, node, opt_str, &idum)) {
if (!tag) {
rval = mbImpl->tag_get_handle(opt_str, 1, MB_TYPE_INTEGER,
- tag, MB_TAG_SPRASE|MB_TAG_CREAT);
+ tag, MB_TAG_SPARSE|MB_TAG_CREAT);
CHKERR(rval, NULL);
@@ -333,7 +333,7 @@
ErrorCode rval;
if (!tag) {
rval = mbImpl->tag_get_handle(opt_str, 1, MB_TYPE_DOUBLE,
CHKERR(rval, NULL);
Modified: MOAB/trunk/src/io/WriteCCMIO.cpp
--- MOAB/trunk/src/io/WriteCCMIO.cpp 2011-06-03 00:50:28 UTC (rev 4936)
+++ MOAB/trunk/src/io/WriteCCMIO.cpp 2011-06-03 01:26:24 UTC (rev 4937)
@@ -123,7 +123,7 @@
impl->tag_get_handle(MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER,
mMaterialSetTag, MB_TAG_SPARSE|MB_TAG_CREAT);
- impl->tag_get_handle(DIRICHLET_SET_TAG_NAME 1, MB_TYPE_INTEGER,
+ impl->tag_get_handle(DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER,
mDirichletSetTag, MB_TAG_SPARSE|MB_TAG_CREAT);
impl->tag_get_handle(NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER,
