[MOAB-dev] r4936 - MOAB/trunk/src/parallel
    Hong-Jun Kim
    hongjun at mcs.anl.gov
    Fri Jun  3 10:38:45 CDT 2011
> You can use whichever you want. MOAB uses MB_TAG_EXCL to get the
> expected
> behavior for the iMesh call. But my comment was with regards to the
> code
> you changed in ParallelComm, which did not use the iMesh call.
Ah, I think I'd better add "MB_TAG_EXCL" to my code in ParallelComm.
Is it right?
Hong-Jun
>> From: "Jason Kraftcheck" <kraftche at cae.wisc.edu>
>> To: moab-dev at mcs.anl.gov
>> Cc: hongjun at mcs.anl.gov
>> Sent: Friday, June 3, 2011 8:51:15 AM
>> Subject: Re: [MOAB-dev] r4936 - MOAB/trunk/src/parallel
>> On 06/02/2011 07:50 PM, hongjun at mcs.anl.gov wrote:
>>> Author: hongjun
>>> Date: 2011-06-02 19:50:28 -0500 (Thu, 02 Jun 2011)
>>> New Revision: 4936
>>> Modified:
>>>     MOAB/trunk/src/parallel/ParallelComm.cpp
>>> Log:
>>> o MB_ALREADY_ALLOCATED case is handled in "un/pack_sets" function
>>> o Passes make check
>> There shouldn't be an 'MB_ALREADY_ALLOCATED case'. If you're getting
>> an
>> error code other than MB_SUCCESS from those functions, then there is
>> something wrong with the arguments (e.g. the tag is not actually 1
>> integer.)
>> - jason
>>> Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
>>> --- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-06-02 22:34:11 UTC
>>> (rev 4935)
>>> +++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-06-03 00:50:28 UTC
>>> (rev 4936)
>>> @@ -2510,7 +2510,7 @@
>>>       std::vector<int> id_data(n_sets);
>>>       result = mbImpl->tag_get_handle("PARALLEL_UNIQUE_ID", 1,
>>>       MB_TYPE_INTEGER,
>>>                                   uid_tag,
>>>                                   MB_TAG_SPARSE|MB_TAG_CREAT);
>>> - if (MB_SUCCESS != result) {
>>> + if (MB_ALREADY_ALLOCATED != result&& MB_SUCCESS != result) {
>>>         RRA("Trouble creating parallel geometry unique id tag.");
>>>       result = mbImpl->tag_get_data(uid_tag, all_sets,&id_data[0]);
>>> @@ -2665,7 +2665,7 @@
>>>       Tag uid_tag; int def_val = 0;
>>>       MB_TYPE_INTEGER,
>>>                                       uid_tag,
>>>                                       MB_TAG_SPARSE|MB_TAG_CREAT,&def_val);
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
