[MOAB-dev] r4936 - MOAB/trunk/src/parallel
Hong-Jun Kim
hongjun at mcs.anl.gov
Fri Jun 3 10:09:51 CDT 2011
To create this tag, I am using "iMesh_createTag" in meshkit which uses "MB_TAG_EXCL" as an argument for moab's "tag_get_handle".
Isn't it make "MB_ALREADY_ALLOCATED" returned?
If it is, do I have to use moab's tag_get_handle instead of iMesh one?
Hong-Jun
----- Original Message -----
> From: "Jason Kraftcheck" <kraftche at cae.wisc.edu>
> To: moab-dev at mcs.anl.gov
> Cc: hongjun at mcs.anl.gov
> Sent: Friday, June 3, 2011 8:51:15 AM
> Subject: Re: [MOAB-dev] r4936 - MOAB/trunk/src/parallel
> On 06/02/2011 07:50 PM, hongjun at mcs.anl.gov wrote:
> > Author: hongjun
> > Date: 2011-06-02 19:50:28 -0500 (Thu, 02 Jun 2011)
> > New Revision: 4936
> > Modified:
> > MOAB/trunk/src/parallel/ParallelComm.cpp
> > Log:
> > o MB_ALREADY_ALLOCATED case is handled in "un/pack_sets" function
> > o Passes make check
> There shouldn't be an 'MB_ALREADY_ALLOCATED case'. If you're getting
> an
> error code other than MB_SUCCESS from those functions, then there is
> something wrong with the arguments (e.g. the tag is not actually 1
> integer.)
> - jason
> > Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
> > --- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-06-02 22:34:11 UTC
> > (rev 4935)
> > +++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-06-03 00:50:28 UTC
> > (rev 4936)
> > @@ -2510,7 +2510,7 @@
> > std::vector<int> id_data(n_sets);
> > result = mbImpl->tag_get_handle("PARALLEL_UNIQUE_ID", 1,
> > MB_TYPE_INTEGER,
> > uid_tag,
> > MB_TAG_SPARSE|MB_TAG_CREAT);
> > - if (MB_SUCCESS != result) {
> > + if (MB_ALREADY_ALLOCATED != result&& MB_SUCCESS != result) {
> > RRA("Trouble creating parallel geometry unique id tag.");
> > result = mbImpl->tag_get_data(uid_tag, all_sets,&id_data[0]);
> > @@ -2665,7 +2665,7 @@
> > Tag uid_tag; int def_val = 0;
> > MB_TYPE_INTEGER,
> > uid_tag,
> > MB_TAG_SPARSE|MB_TAG_CREAT,&def_val);
