[MOAB-dev] r4936 - MOAB/trunk/src/parallel
Jason Kraftcheck
kraftche at cae.wisc.edu
Fri Jun 3 08:51:15 CDT 2011
On 06/02/2011 07:50 PM, hongjun at mcs.anl.gov wrote:
> Author: hongjun
> Date: 2011-06-02 19:50:28 -0500 (Thu, 02 Jun 2011)
> New Revision: 4936
> Modified:
> MOAB/trunk/src/parallel/ParallelComm.cpp
> Log:
> o MB_ALREADY_ALLOCATED case is handled in "un/pack_sets" function
> o Passes make check
There shouldn't be an 'MB_ALREADY_ALLOCATED case'. If you're getting an
error code other than MB_SUCCESS from those functions, then there is
something wrong with the arguments (e.g. the tag is not actually 1 integer.)
- jason
> Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
> --- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-06-02 22:34:11 UTC (rev 4935)
> +++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-06-03 00:50:28 UTC (rev 4936)
> @@ -2510,7 +2510,7 @@
> std::vector<int> id_data(n_sets);
> result = mbImpl->tag_get_handle("PARALLEL_UNIQUE_ID", 1, MB_TYPE_INTEGER,
> uid_tag, MB_TAG_SPARSE|MB_TAG_CREAT);
> - if (MB_SUCCESS != result) {
> + if (MB_ALREADY_ALLOCATED != result&& MB_SUCCESS != result) {
> RRA("Trouble creating parallel geometry unique id tag.");
> result = mbImpl->tag_get_data(uid_tag, all_sets,&id_data[0]);
> @@ -2665,7 +2665,7 @@
> Tag uid_tag; int def_val = 0;
> uid_tag, MB_TAG_SPARSE|MB_TAG_CREAT,&def_val);
