[MOAB-dev] r4931 - MOAB/trunk/src
iulian at mcs.anl.gov iulian at mcs.anl.gov
Thu Jun 2 15:40:36 CDT 2011
Author: iulian
Date: 2011-06-02 15:40:36 -0500 (Thu, 02 Jun 2011)
New Revision: 4931
Modified:
   MOAB/trunk/src/FBEngine.cpp
Log:
error pretty hard to track, as it was showing on optimized version only.
And it showed on optimized version because ray tracing returned
a different intersected triangle (at the same node)
it opened other questions about robustness of the splitting in general, and
the usefulness of the method :(
we should avoid small edges and angles, by adjusting the splitting line
to the close nodes on the surface. Introducing small edges is not beneficial
at all to the "mesh-based" geometry. It is downright stupid.
changed the default tolerance to 0.01, which means 1 cm. It should be
something relative to the size of the model (box)
Modified: MOAB/trunk/src/FBEngine.cpp
--- MOAB/trunk/src/FBEngine.cpp	2011-06-02 20:29:33 UTC (rev 4930)
+++ MOAB/trunk/src/FBEngine.cpp	2011-06-02 20:40:36 UTC (rev 4931)
@@ -29,7 +29,11 @@
 unsigned min_tolerace_intersections = 1000;
 double tolerance = 0.01; // TODO: how is this used ????
-double tolerance_segment = 0.000001; // for segments intersection, points collapse
+double tolerance_segment = 0.01; // for segments intersection, points collapse, area coordinates for triangles
+// it should be a relative, not an absolute value
+// as this splitting operation can create small edges, it should be relatively high
+// or, it should be coordinated with the decimation errors
+// we really just want to preserve the integrity of the mesh, we should avoid creating small edges or angles
 const bool Debug_surf_eval = false;
 bool debug_splits = false;
@@ -99,6 +103,11 @@
   CartVect r0(P[0] - pnt);
   CartVect r1(P[1] - pnt);
   CartVect r2(P[2] - pnt);
+  if (debug_splits)
+    std::cout << " nodes:" << conn3[0] << " "<<  conn3[1] << " " << conn3[2] <<"\n";
+    std::cout << " distances: " << r0.length() << " " << r1.length() << " " << r2.length() << "\n";
   if (r0.length() < tolerance_segment) {
     area_coord[0] = 1.;
     area_coord[1] = 0.;
@@ -113,7 +122,7 @@
     boundary_handle = conn3[1];
     return MB_SUCCESS;
-  if (r1.length() < tolerance_segment) {
+  if (r2.length() < tolerance_segment) {
     area_coord[0] = 0.;
     area_coord[1] = 0.;
     area_coord[2] = 1.;
@@ -1169,6 +1178,13 @@
       rval = area_coordinates(_mbImpl, facets_out[index], newPoint, area_coord, boundary_handle);
       MBERRORR(rval, "Failed to get area coordinates");
+      if (debug_splits)
+        std::cout <<" int point:" << newPoint << " area coord " << area_coord[0] << " "
+           <<  area_coord[1] << " " << area_coord[2] << "\n";
+        std::cout << " triangle: " <<
+            _mbImpl->id_from_handle(facets_out[index]) << " boundary:" <<  boundary_handle <<  "\n";
       EntityType type;
       if (boundary_handle)
