[MOAB-dev] r4900 - in MOAB/trunk/src: moab parallel
tautges at mcs.anl.gov
Tue May 31 15:52:27 CDT 2011
Author: tautges
Date: 2011-05-31 15:52:26 -0500 (Tue, 31 May 2011)
New Revision: 4900
Modified:
MOAB/trunk/src/moab/Skinner.hpp
MOAB/trunk/src/parallel/ParallelComm.cpp
Log:
Fixing the problem with skinning I introduced on Fri, and clarifying
documentation on one of the skinning functions.
Modified: MOAB/trunk/src/moab/Skinner.hpp
--- MOAB/trunk/src/moab/Skinner.hpp 2011-05-31 18:14:55 UTC (rev 4899)
+++ MOAB/trunk/src/moab/Skinner.hpp 2011-05-31 20:52:26 UTC (rev 4900)
@@ -56,10 +56,12 @@
ErrorCode find_geometric_skin(Range &forward_target_entities);
/**\brief will accept entities all of one dimension and
- * return entities of n-1 dimension
+ * return entities of n-1 dimension; NOTE: get_vertices argument controls whether
+ * vertices or entities of n-1 dimension are returned, and only one of these is allowed
+ * (i.e. this function returns only vertices or (n-1)-dimensional entities, but not both)
* \param entities The elements for which to find the skin
- * \param get_vertices If true, vertices on the skin are also returned
- * in the range
+ * \param get_vertices If true, vertices on the skin are returned
+ * in the range, otherwise elements are returned
* \param output_handles Range holding skin entities returned
* \param output_reverse_handles Range holding entities on skin which
* are reversed wrt entities
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-05-31 18:14:55 UTC (rev 4899)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-05-31 20:52:26 UTC (rev 4900)
@@ -3231,15 +3231,13 @@
// find the skin
Skinner skinner(mbImpl);
- result = skinner.find_skin(skin_ents[skin_dim+1], true, skin_ents[skin_dim],
+ result = skinner.find_skin(skin_ents[skin_dim+1], false, skin_ents[skin_dim],
NULL, true, true, true);
RRA("Failed to find skin.");
myDebug->tprintf(1, "Found skin, now resolving.\n");
// get entities adjacent to skin ents from shared_dim down to zero
- skin_ents[0] = skin_ents[skin_dim].subset_by_type(MBVERTEX);
- skin_ents[skin_dim] -= skin_ents[0];
- for (int this_dim = skin_dim-1; this_dim > 0; this_dim--) {
+ for (int this_dim = skin_dim-1; this_dim >= 0; this_dim--) {
result = mbImpl->get_adjacencies(skin_ents[skin_dim], this_dim,
true, skin_ents[this_dim],
Interface::UNION);
