[MOAB-dev] Parallel builds need make clean
Tim Tautges
tautges at mcs.anl.gov
Tue May 31 13:56:06 CDT 2011
I'm now seeing this error too, don't know why I wasn't before. Tracking it down now...
- tim
On 05/31/2011 01:49 PM, Iulian Grindeanu wrote:
> The first error trace for me:
> gdb) backtrace
> #0 get_sharing_processors (moab=..., entity=3, other_procs_out=...) at parallel_unit_tests.cpp:261
> #1 0x000000000040e042 in test_elements_on_several_procs (filename=0x6549d0 "../../MeshFiles/unittest/64bricks_512hex.h5m") at parallel_unit_tests.cpp:449
> #2 0x000000000040c3a0 in run_test (func=0x40da85<test_elements_on_several_procs(char const*)>, func_name=0x654a28 "test_elements_on_several_procs", file_name=0x6549d0 "../../MeshFiles/unittest/64bricks_512hex.h5m") at parallel_unit_tests.cpp:140
> #3 0x000000000040c6c8 in main (argc=1, argv=0x7fffffffe088) at parallel_unit_tests.cpp:207
> (gdb)
> It seems that after loading the file, __PARALLEL_SHARED_PROC tag is not found.
> I thought that these tags should be created when loading the file with proper parallel options.
> Is this related to the error Hong Jun reported? This is the first test in parallel_unit_tests.
> Iulian
>> Hmm, I haven't seen this. I'll test now...
>> - tim
>> On 05/31/2011 01:00 PM, Hong-Jun Kim wrote:
>>> By debugging more, in "Skinner::find_skin_scd" function,
>>> "box_dims_tag" seems not defined before skinning.
>>> Hong-Jun
>>>> From: "Hong-Jun Kim"<hongjun at mcs.anl.gov>
>>>> To: "Tim Tautges"<tautges at mcs.anl.gov>
>>>> Cc: moab-dev at mcs.anl.gov
>>>> Sent: Tuesday, May 31, 2011 12:55:44 PM
>>>> Subject: Re: [MOAB-dev] Parallel builds need make clean
>>>> Even after "make clean" or "make distclean", I still have the
>>>> problems.
>>>> In "test_ghost_elements" test of "parallel_unit_tests.cpp",
>>>> "get_expected_ghosts" function returns 0 expected ghosts which is
>>>> wrong.
>>>> It seems "Skinner" has problem to get 2d element skin for
>>>> structured
>>>> mesh(?) in "resolve_shared_ents" function when mesh file is loaded.
>>>> Skinner looks just get vertex elements instead of getting 2d
>>>> elements.
>>>> Hong-Jun
>>>>> From: "Tim Tautges"<tautges at mcs.anl.gov>
>>>>> To: moab-dev at mcs.anl.gov
>>>>> Sent: Tuesday, May 31, 2011 12:07:56 PM
>>>>> Subject: [MOAB-dev] Parallel builds need make clean
>>>>> Hi all,
>>>>> I've had a number of people ask about this, so thought I'd send a
>>>>> general note - a recent change is causing existing
>>>>> parallel builds to fail the make check; you'll have to do a 'make
>>>>> clean' then remake, then the checks should run
>>>>> successfully again.
>>>>> - tim
>>>>> "You will keep in perfect peace him whose mind is
>>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>>> Tim Tautges Argonne National Laboratory
>>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>>> phone: (608) 263-8485 1500 Engineering Dr.
>>>>> fax: (608) 263-4499 Madison, WI 53706
