[MOAB-dev] build question
Tim Tautges tautges at mcs.anl.gov
Tue May 24 11:48:47 CDT 2011
Nope, the one in WriteHDF5Parallel is in the moab namespace.
- tim
On 05/24/2011 11:39 AM, iulian at mcs.anl.gov wrote:
>> On 05/24/2011 11:08 AM, Iulian Grindeanu wrote:
>>> It is now a static build; I will set the PATH and LD_LIBRARY_PATH to
>>> point to the same mpich, and I will let you know
>>> On my laptop (32 bit) works fine too, I am using default mpich from
>>> synaptic
> Still doesn't work;
> Rajeev noted that while debugging meshkit, CpuTimer class from ./MOAB/src/parallel/WriteHDF5Parallel.cpp:class CpuTimer {...  was invoked while being in cgm code.
> (there are 2 CpuTimer classes). He is using a shared, occ based build.
> Could that be a problem?
> Iulian
>> On one of your earlier messages you were specifying
>> --with-mpi=/home/fathom/..., I think for MOAB.
>>> I am wondering why the error appears only for cubit-based cgm
>> For cubit-based cgm, you'll have at least some shared libs, since
>> that's the only way cubit libs are distributed. Maybe
>> in your non-cubit cgm you have true static libs.
>> - tim
>>>> If this is a shared build, then the test file is actually a shell
>>>> script, the actual executable is in the .libs
>>>> directory under that.
>>>> - tim
>>>> On 05/24/2011 10:50 AM, Jason Kraftcheck wrote:
>>>>> On 05/24/2011 10:44 AM, Iulian Grindeanu wrote:
>>>>>> FAIL: partest (exit: 1)
>>>>>> Attempting to use an MPI routine before initializing MPICH
>>>>>> The debugger will not start, and I don't know which one is called
>>>>>> before MPI_Init
>>>>> The debugger will not start? Assuming you figure out what is going
>>>>> on with
>>>>> that, try setting break points in MPI_Comm_rank and MPI_Comm_size.
>>>>> Most
>>>>> codes using MPI call at least one of those before anything else.
>>>>> - jason
>>>> "You will keep in perfect peace him whose mind is
>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>> Tim Tautges Argonne National Laboratory
>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>> phone: (608) 263-8485 1500 Engineering Dr.
>>>> fax: (608) 263-4499 Madison, WI 53706
