[MOAB-dev] build question
iulian at mcs.anl.gov
Tue May 24 11:39:15 CDT 2011
----- Original Message -----
> On 05/24/2011 11:08 AM, Iulian Grindeanu wrote:
> > It is now a static build; I will set the PATH and LD_LIBRARY_PATH to
> > point to the same mpich, and I will let you know
> > On my laptop (32 bit) works fine too, I am using default mpich from
> > synaptic
Still doesn't work;
Rajeev noted that while debugging meshkit, CpuTimer class from ./MOAB/src/parallel/WriteHDF5Parallel.cpp:class CpuTimer {... was invoked while being in cgm code.
(there are 2 CpuTimer classes). He is using a shared, occ based build.
Could that be a problem?
Iulian
> On one of your earlier messages you were specifying
> --with-mpi=/home/fathom/..., I think for MOAB.
> > I am wondering why the error appears only for cubit-based cgm
> For cubit-based cgm, you'll have at least some shared libs, since
> that's the only way cubit libs are distributed. Maybe
> in your non-cubit cgm you have true static libs.
> - tim
> >> If this is a shared build, then the test file is actually a shell
> >> script, the actual executable is in the .libs
> >> directory under that.
> >> - tim
> >> On 05/24/2011 10:50 AM, Jason Kraftcheck wrote:
> >>> On 05/24/2011 10:44 AM, Iulian Grindeanu wrote:
> >>>> FAIL: partest (exit: 1)
> >>>> Attempting to use an MPI routine before initializing MPICH
> >>>> The debugger will not start, and I don't know which one is called
> >>>> before MPI_Init
> >>> The debugger will not start? Assuming you figure out what is going
> >>> on with
> >>> that, try setting break points in MPI_Comm_rank and MPI_Comm_size.
> >>> Most
> >>> codes using MPI call at least one of those before anything else.
> >>> - jason
> >> "You will keep in perfect peace him whose mind is
> >> steadfast, because he trusts in you." Isaiah 26:3
> >> Tim Tautges Argonne National Laboratory
> >> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> >> phone: (608) 263-8485 1500 Engineering Dr.
> >> fax: (608) 263-4499 Madison, WI 53706
