[MOAB-dev] r4859 - in MOAB/trunk: MeshFiles/unittest test
iulian at mcs.anl.gov iulian at mcs.anl.gov
Mon May 23 00:08:56 CDT 2011
Author: iulian
Date: 2011-05-23 00:08:55 -0500 (Mon, 23 May 2011)
New Revision: 4859
Added:
   MOAB/trunk/MeshFiles/unittest/quads.h5m
Modified:
   MOAB/trunk/test/mbfacet_test.cpp
Log:
test automatic splitting of quads for mesh-based smooth geometry
Added: MOAB/trunk/MeshFiles/unittest/quads.h5m
(Binary files differ)
Property changes on: MOAB/trunk/MeshFiles/unittest/quads.h5m
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: MOAB/trunk/test/mbfacet_test.cpp
--- MOAB/trunk/test/mbfacet_test.cpp	2011-05-21 21:05:31 UTC (rev 4858)
+++ MOAB/trunk/test/mbfacet_test.cpp	2011-05-23 05:08:55 UTC (rev 4859)
@@ -36,6 +36,9 @@
 std::string filename;
 std::string filename_out;
 std::string polygon_file_name;
+std::string quads_file;
 bool keep_output;
 int number_tests_successful = 0;
 int number_tests_failed = 0;
@@ -63,6 +66,8 @@
 ErrorCode check_split(Interface * mb, FBEngine * pFacet);
 ErrorCode split_test_across();
+ErrorCode split_quads_test();
 void handle_error_code(ErrorCode rv, int &number_failed, int &number_successful)
   if (rv == MB_SUCCESS) {
@@ -79,16 +84,20 @@
   filename = TestDir + "/PB.h5m";
   polygon_file_name = TestDir + "/polyPB.txt";
   filename_out = "PB_new.h5m";
+  quads_file = TestDir + "/quads.h5m";
   keep_output = false;
   if (argc == 1) {
     std::cout << "Using default input files: " << filename << " " << polygon_file_name <<
         " " << std::endl;
     std::cout << "    default output file: " << filename_out << " will be deleted \n";
-  } else if (argc >=4) {
+    std::cout << "    quads test file: " << quads_file << "\n";
+  } else if (argc >=5) {
     filename = argv[1];
     polygon_file_name = argv[2];
     filename_out = argv[3];
