[MOAB-dev] Dense tag behavior
Lorenzo Alessio Botti bottilorenzo at gmail.com
Fri May 13 04:21:05 CDT 2011
Hi all,
It seems that dense tag memory is allocated when the tag is set for at least one entity of a given type.
This is documented in the MOAB User's Guide. I missed it.
"Storage for a given dense tag is not allocated until a tag value is set on an entity; memory for a given dense tag is allocated for all entities in a given sequence at the same time."
I would have expected the dense tag to be associated with the default value to all the entities in the mesh.
Thanks
Lorenzo
On May 12, 2011, at 4:43 PM, Tim Tautges wrote:
> Probably when the tag was created, it was not created with a default value.  This could be the case if the vtk reader created it upon finding it in the file.
> One way around this would be to create a tag of the proper name/data type/storage type/default value before reading the vtk file; then the vtk reader will use that tag, and your quads will get the default value too.
> The tris being set has to do with how storage for tags is allocated (based on sequences, the fundamental unit of storage in MOAB).
> - tim
> On 05/12/2011 09:31 AM, Lorenzo Botti wrote:
>> I'm noticing a strange behavior of dense tags.
>> I'm reading a hybrid tets+prisms+tris (tris represent the boundary mesh) vtk mesh where I have an id (type int) associated to each cell in order to define boundary conditions.
>> The ids are correctly represented in MOAB as a dense tag over the mesh elements.
>> However If I build 2D internal faces (tris and quads) with get_adjacencies only tris obtain the dense tag (set by default to 0?) while quads are tag free.
>> Does it work this way because no tags have been associated to quads?
>> Thanks
>> Lorenzo
> "You will keep in perfect peace him whose mind is
>  steadfast, because he trusts in you."               Isaiah 26:3
>             Tim Tautges            Argonne National Laboratory
>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>         phone: (608) 263-8485      1500 Engineering Dr.
>           fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110513/0719bfe0/attachment.htm>
