[MOAB-dev] r4812 - in MOAB/trunk: src src/moab test
iulian at mcs.anl.gov
Tue May 10 16:06:35 CDT 2011
Author: iulian
Date: 2011-05-10 16:06:34 -0500 (Tue, 10 May 2011)
New Revision: 4812
Modified:
MOAB/trunk/src/FBEngine.cpp
MOAB/trunk/src/moab/FBEngine.hpp
MOAB/trunk/test/mbfacet_test.cpp
Log:
fix bugs in splitting facet-based geometry faces
set neumann tags (mostly for debugging)
start filling for the 2 faces from the splitting line
first range is to the left (positive sense) , second range to the right
(negative sense)
Modified: MOAB/trunk/src/FBEngine.cpp
--- MOAB/trunk/src/FBEngine.cpp 2011-05-10 17:06:06 UTC (rev 4811)
+++ MOAB/trunk/src/FBEngine.cpp 2011-05-10 21:06:34 UTC (rev 4812)
@@ -29,7 +29,7 @@
double tolerance = 0.01; // TODO: how is this used ????
double tolerance_segment = 0.000001; // for segments intersection, points collapse
const bool Debug_surf_eval = false;
-bool debug_splits = false;// false?
+bool debug_splits = false;
// will compute intersection between a segment and slice of a plane
// output is the intersection point
@@ -1336,53 +1336,10 @@
_my_geomTopoTool->add_geo_set(new_geo_edge, 1);
for (unsigned int k=0; k< geo_vertices.size(); k++)
_my_geomTopoTool->add_geo_set(geo_vertices[k], 0);
- // new face will have the new edge oriented positively
- // get a mesh edge from geo edge;
- Range mesh_edges;
- rval = _mbImpl->get_entities_by_type(new_geo_edge, MBEDGE, mesh_edges);
- MBERRORR(rval, "can't get new polyline edges");
- // get a positive triangle adjacent to mesh_edge[0]
- Range adj_tri;
- EntityHandle firstMeshEdge = mesh_edges[0];
- rval = _mbImpl->get_adjacencies(&firstMeshEdge, 1,
- 2, false, adj_tri, Interface::UNION);
- MBERRORR(rval, "can't get adj_tris to first edge");
- EntityHandle pTriangle;
- Range::iterator it=adj_tri.begin();
- for ( ; it!=adj_tri.end(); it++)
- EntityHandle tr=*it;
- int num1, sense, offset;
- rval = _mbImpl->side_number(tr, mesh_edges[0], num1, sense, offset);
- MBERRORR(rval, "edge not adjacent");
- if (sense==1)
- pTriangle = tr;
- break;
- if (it==adj_tri.end())
- MBERRORR(MB_FAILURE, "can't get a positive triangle");
- bool firstIsNewFace = true;
- if ( first.find(pTriangle)!=first.end())
