[MOAB-dev] r4809 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Mon May 9 17:30:37 CDT 2011
Author: kraftche
Date: 2011-05-09 17:30:36 -0500 (Mon, 09 May 2011)
New Revision: 4809
Modified:
   MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
   MOAB/trunk/src/parallel/WriteHDF5Parallel.hpp
Log:
remove allgatherv when negotiating tags for parallel hdf5 write (replaced with two bcasts in the fast case, plus an unlikely gather and gatherv in the slow case)
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp	2011-05-09 17:13:56 UTC (rev 4808)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp	2011-05-09 22:30:36 UTC (rev 4809)
@@ -103,7 +103,38 @@
 #endif
+static int my_Gatherv( void* sendbuf,
+                       int sendcount,
+                       MPI_Datatype sendtype,
+                       std::vector<unsigned char>& recvbuf,
+                       std::vector<int>& recvcounts,
+                       int root,
+                       MPI_Comm comm )
+  int nproc, rank, bytes, err;
+  MPI_Comm_size( comm, &nproc );
+  MPI_Comm_rank( comm, &rank );
+  MPI_Type_size( sendtype, &bytes );
+  recvcounts.resize( rank == root ? nproc : 0 );
+  err = MPI_Gather( &sendcount, 1, MPI_INT, &recvcounts[0], 1, MPI_INT, root, comm );
+  if (MPI_SUCCESS != err) return err;
+  std::vector<int> disp(recvcounts.size());
+  if (root == rank) {
+    disp[0] = 0;
+    for (int i = 1; i < nproc; ++i)
+      disp[i] = disp[i-1] + recvcounts[i-1];
+    recvbuf.resize( bytes * (disp.back() + recvcounts.back()) );
+  return MPI_Gatherv( sendbuf, sendcount, sendtype,
+                      &recvbuf[0], &recvcounts[0], &disp[0],
+                      sendtype, root, comm );
 // This function doesn't do anything useful.  It's just a nice
 // place to set a break point to determine why the reader fails.
 static inline ErrorCode error( ErrorCode rval )
@@ -512,67 +543,30 @@
-static void set_bit( int position, unsigned char* bytes )
+ErrorCode WriteHDF5Parallel::check_serial_tag_data(
+                               const std::vector<unsigned char>& buffer,
+                               std::vector<TagDesc*>* missing,
