[MOAB-dev] r4805 - in MOAB/trunk: src/io src/io/mhdf/example src/io/mhdf/include src/io/mhdf/src src/parallel test/h5file test/parallel
kraftche at cae.wisc.edu
Fri May 6 16:31:48 CDT 2011
Author: kraftche
Date: 2011-05-06 16:31:47 -0500 (Fri, 06 May 2011)
New Revision: 4805
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
MOAB/trunk/src/io/WriteHDF5.cpp
MOAB/trunk/src/io/mhdf/example/info.c
MOAB/trunk/src/io/mhdf/example/validate.c
MOAB/trunk/src/io/mhdf/include/mhdf.h
MOAB/trunk/src/io/mhdf/src/adjacency.c
MOAB/trunk/src/io/mhdf/src/connectivity.c
MOAB/trunk/src/io/mhdf/src/file-handle.c
MOAB/trunk/src/io/mhdf/src/file-handle.h
MOAB/trunk/src/io/mhdf/src/file.c
MOAB/trunk/src/io/mhdf/src/sets.c
MOAB/trunk/src/io/mhdf/src/tags.c
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/test/h5file/dump_sets.c
MOAB/trunk/test/parallel/mhdf_parallel.c
Log:
eliminate data conversion during HDF5 write by being consistent about the types used
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2011-05-06 16:30:39 UTC (rev 4804)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-05-06 21:31:47 UTC (rev 4805)
@@ -411,7 +411,7 @@
err = H5Pset_fapl_mpio(file_prop, MPI_COMM_SELF, MPI_INFO_NULL);
assert(file_prop >= 0);
assert(err >= 0);
- filePtr = mhdf_openFileWithOpt( pfilename.c_str(), 0, NULL, file_prop, &status );
+ filePtr = mhdf_openFileWithOpt( pfilename.c_str(), 0, NULL, handleType, file_prop, &status );
H5Pclose( file_prop );
if (filePtr) {
@@ -456,7 +456,7 @@
// re-open file in parallel
dbgOut.tprintf( 1, "Opening \"%s\" for parallel IO\n", pfilename.c_str() );
if (!filePtr)
@@ -485,7 +485,7 @@
else {
// Open the file
- filePtr = mhdf_openFile( filename, 0, NULL, &status );
+ filePtr = mhdf_openFile( filename, 0, NULL, handleType, &status );
if (!filePtr)
readUtil->report_error( "%s", mhdf_message( &status ));
Modified: MOAB/trunk/src/io/WriteHDF5.cpp
--- MOAB/trunk/src/io/WriteHDF5.cpp 2011-05-06 16:30:39 UTC (rev 4804)
+++ MOAB/trunk/src/io/WriteHDF5.cpp 2011-05-06 21:31:47 UTC (rev 4805)
@@ -1390,8 +1390,8 @@
dbgOut.print(3,"Non-shared sets", setSet.range );
/* counts and buffers and such */
- long* const buffer = reinterpret_cast<long*>(dataBuffer);
- const size_t buffer_size = bufferSize / (4*sizeof(long));
+ mhdf_index_t* const buffer = reinterpret_cast<mhdf_index_t*>(dataBuffer);
+ const size_t buffer_size = bufferSize / (4*sizeof(mhdf_index_t));
const size_t num_local_writes = (setSet.range.size() + buffer_size - 1) / buffer_size;
const size_t num_global_writes = (setSet.max_num_ents + buffer_size-1) / buffer_size;
assert(num_local_writes <= num_global_writes);
@@ -1404,12 +1404,12 @@
Range::const_iterator i = setSet.range.begin();
Range::const_iterator r = ranged_sets.begin();
Range::const_iterator s = null_stripped_sets.begin();
