[MOAB-dev] r4802 - MOAB/trunk/src/parallel
    kraftche at cae.wisc.edu
    Thu May  5 13:28:29 CDT 2011
Author: kraftche
Date: 2011-05-05 13:28:29 -0500 (Thu, 05 May 2011)
New Revision: 4802
Modified:
   MOAB/trunk/src/parallel/ReadParallel.cpp
Log:
tweak output for CPUTIME option to ReadParallel: print max operation time over all procs rather than root proc time, and include overall time for read
Modified: MOAB/trunk/src/parallel/ReadParallel.cpp
--- MOAB/trunk/src/parallel/ReadParallel.cpp	2011-05-05 17:22:43 UTC (rev 4801)
+++ MOAB/trunk/src/parallel/ReadParallel.cpp	2011-05-05 18:28:29 UTC (rev 4802)
@@ -512,16 +512,27 @@
       result = tmp_result;
-  if (cputime && 0 == myPcomm->proc_config().proc_rank()) {
-    std::cout << "Read times: ";
-    for (i = 1, vit = pa_vec.begin();
-         vit != pa_vec.end(); vit++, i++)
-      std::cout << act_times[i] - act_times[i-1] << " ";
-    std::cout << "(";
-    for (vit = pa_vec.begin();
-         vit != pa_vec.end(); vit++)
-      std::cout << ParallelActionsNames[*vit] << "/";
-    std::cout << ")" << std::endl;
+  if (cputime) {
+    for (i = pa_vec.size(); i > 0; i--)
+      act_times[i] -= act_times[i-1];
+      // replace initial time with overall time
+    act_times[0] = MPI_Wtime() - act_times[0];
+      // get the maximum over all procs
+    if (0 != myPcomm->proc_config().proc_rank()) {
+      MPI_Reduce( &act_times[0], 0, pa_vec.size()+1, MPI_DOUBLE, MPI_MAX,
+                  0, myPcomm->proc_config().proc_comm());
+    else {
+      MPI_Reduce( MPI_IN_PLACE, &act_times[0], pa_vec.size()+1, MPI_DOUBLE,
+                  MPI_MAX, 0, myPcomm->proc_config().proc_comm());
+      std::cout << "Parallel Read times: " << std::endl;
+      for (i = 1, vit = pa_vec.begin(); vit != pa_vec.end(); vit++, i++)
+          std::cout << "  " << act_times[i] << " "
+                    << ParallelActionsNames[*vit] << std::endl;
+      std::cout << "  " << act_times[0] << " PARALLEL TOTAL" << std::endl;
   if (MB_SUCCESS == result && file_set_ptr) {
