[MOAB-dev] buildbot failure in moab-distcheck: failed compile
Iulian Grindeanu iulian at mcs.anl.gov
Wed Apr 20 09:12:55 CDT 2011
Hi Jason,
I realized I am leaving some test files in MeshFiles/unittest folder.
Are they treated differently? ( I didn't see a make distclean error due to that; I think the file in question is PB_new.h5m)
Should I add them to the Makefile.am there or not?
Also, another question is how to remove a file after a test is done?
Is there a way to do it in Makefile.am? (so right after make check?)
Iulian
----- Original Message -----
> On 04/20/2011 12:27 AM, moab-dev at mcs.anl.gov wrote:
> >   Fathom <http://gnep.mcs.anl.gov:8010/>: moab-distcheck
> >   <http://gnep.mcs.anl.gov:8010/builders/moab-distcheck> build #476
> >   <http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/476>
> > *Results:* failed compile
> > *Buildslave:* gnep
> > *Revision:* None
> > *Reason:* The Nightly scheduler named 'nightly' triggered this build
> >     Log Excerpt
> > ERROR: files left in build directory after distclean:
> > ./test/output.h5m
> Iulian,
> I'm guessing that this was due to your changes as you were the last
> person
> to check in testing code to MOAB. Apologies if I'm mistaken in that
> assumption.
> This error is because the automake expects (rightly) that 'make clean'
> will
> clean up all files generated by building and testing, including any
> output
> files generated by tests. If you don't expect to be looking at this
> output
> file much in the future (e.g. you're writing the file so you can check
> that
> it was written correctly by reading it back in), then the best
> solution is
> probably to call remove(filename) before your test exits. If that is
> not
> acceptable, then the other solution is to add the file name to the
> MOSTLYCLEANFILES variable in the Makefile.am.
> - jason
