[MOAB-dev] compile error
Iulian Grindeanu iulian at mcs.anl.gov
Thu Mar 31 23:51:00 CDT 2011
Hello,
I am wondering if anyone got this compile error:
  CXX    WriteSLAC.lo
  CXX    ReadNC.lo
  CXX    ReadHDF5.lo
ReadHDF5.cpp: In function ‘herr_t moab::handle_hdf5_error(void*)’:
ReadHDF5.cpp:124: error: ‘dbgOut’ was not declared in this scope
ReadHDF5.cpp: In member function ‘moab::ErrorCode moab::ReadHDF5::load_file_partial(const moab::ReaderIface::IDTag*, int, int, int, const moab::FileOptions&)’:
ReadHDF5.cpp:923: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 4 has type ‘moab::EntityHandle’
ReadHDF5.cpp:923: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 5 has type ‘size_t’
ReadHDF5.cpp: In member function ‘moab::ErrorCode moab::ReadHDF5::read_elems(const mhdf_ElemDesc&, const moab::Range&, moab::Range*)’:
ReadHDF5.cpp:1425: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 5 has type ‘moab::EntityHandle’
ReadHDF5.cpp:1425: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 6 has type ‘size_t’
ReadHDF5.cpp: In member function ‘moab::ErrorCode moab::ReadHDF5::read_elems(int, const moab::Range&, moab::Range&)’:
ReadHDF5.cpp:1648: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 5 has type ‘moab::EntityHandle’
ReadHDF5.cpp:1648: warning: format ‘%lu’ expects type ‘long unsigned int’, but argument 6 has type ‘size_t’
make[5]: *** [ReadHDF5.lo] Error 1
make[5]: Leaving directory `/home/iulian/source/MOAB/src/io'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory `/home/iulian/source/MOAB/src/io'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/iulian/source/MOAB/src'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/iulian/source/MOAB/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/iulian/source/MOAB'
make: *** [all] Error 2
This is configured with cgm+cubit 12, 32 bit version.
Iulian
