[MOAB-dev] r4707 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Thu Mar 31 18:30:30 CDT 2011
Author: kraftche
Date: 2011-03-31 18:30:30 -0500 (Thu, 31 Mar 2011)
New Revision: 4707
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
Log:
propogate correct error code to caller in ReadHDF5, and a little more error output
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2011-03-31 23:30:02 UTC (rev 4706)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-03-31 23:30:30 UTC (rev 4707)
@@ -561,8 +561,11 @@
if (MB_SUCCESS == rval)
dbgOut.tprint(1, "Read finished.\n");
- else
- dbgOut.tprintf(1,"READ FAILED (ERROR CODE %d)\n", (int)rval);
+ else {
+ std::string msg;
+ iFace->get_last_error(msg);
+ dbgOut.tprintf(1,"READ FAILED (ERROR CODE %s): %s\n", ErrorCodeStr[rval], msg.c_str());
if (H5P_DEFAULT != collIO)
H5Pclose( collIO );
@@ -3236,10 +3239,8 @@
rval = iFace->tag_set_data( tag_handle, ents, dataBuffer );
if (MB_SUCCESS != rval) {
- std::string err;
- iFace->get_last_error(err);
- dbgOut.printf(1,"Internal error setting data for tag \"%s\": %s\n", tn.c_str(), err.c_str());
- return error(MB_FAILURE);
+ dbgOut.printf(1,"Internal error setting data for tag \"%s\"\n", tn.c_str());
+ return error(rval);
