[MOAB-dev] r4698 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Thu Mar 31 13:08:27 CDT 2011
Author: kraftche
Date: 2011-03-31 13:08:27 -0500 (Thu, 31 Mar 2011)
New Revision: 4698
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
MOAB/trunk/src/io/ReadHDF5VarLen.hpp
Log:
more informative error handling
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2011-03-31 16:44:31 UTC (rev 4697)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-03-31 18:08:27 UTC (rev 4698)
@@ -81,11 +81,23 @@
#define assert_range( PTR, CNT ) \
assert( (PTR) >= (void*)dataBuffer ); assert( ((PTR)+(CNT)) <= (void*)(dataBuffer + bufferSize) );
+#define error(A) process_error(A,&dbgOut,__FILE__,__LINE__)
// This function doesn't do anything useful. It's just a nice
// place to set a break point to determine why the reader fails.
-static inline ErrorCode error( ErrorCode rval )
- { return rval; }
+//static inline ErrorCode process_error( ErrorCode rval )
+// { return rval; }
+static inline ErrorCode process_error(ErrorCode code, DebugOutput* dbgOut, const char* file, int line)
+ if (MB_SUCCESS != code) {
+ if (dbgOut)
+ dbgOut->printf(1,"Failure with error code %d at %s:%d\n", (int)code, file, line);
+#if defined(WITH_MPI) && !defined(NDEBUG)
+ MPI_Abort( MPI_COMM_WORLD ):
+#endif
+ return code;
// Call \c error function during HDF5 library errors to make
// it easier to trap such errors in the debugger. This function
@@ -99,7 +111,7 @@
herr_t result = 0;
if (h->func)
result = (*h->func)(stack,h->data);
- error(MB_FAILURE);
+ process_error(MB_FAILURE,0,__FILE__,__LINE__);
return result;
#else
@@ -547,7 +559,10 @@
if (rval == MB_SUCCESS && rval2 != MB_SUCCESS)
rval = rval2;
- dbgOut.tprint(1, "Read finished.\n");
+ if (MB_SUCCESS == rval)
+ dbgOut.tprint(1, "Read finished.\n");
+ else
+ dbgOut.tprintf(1,"READ FAILED (ERROR CODE %d)\n", (int)rval);
if (H5P_DEFAULT != collIO)
H5Pclose( collIO );
