[MOAB-dev] r4696 - MOAB/trunk/src/io
Steve Jackson sjackson at cae.wisc.edu
Thu Mar 31 10:50:27 CDT 2011
R4696 seems to fix the problem, and DagMC is working again.  Thank you for such a quick fix, Iulian!
~S
On Mar 30, 2011, at 22:00 , Iulian Grindeanu wrote:
> Hi Steve,
> Can you please check if this fixes dagmc?
> I am not sure ...
> Thanks,
> Iulian
> ----- Forwarded Message -----
>> Author: iulian
>> Date: 2011-03-30 21:58:48 -0500 (Wed, 30 Mar 2011)
>> New Revision: 4696
>> Modified:
>> MOAB/trunk/src/io/ReadCGM.cpp
>> Log:
>> the convention for senses is now changed: +1 is forward, -1 is
>> reverse,
>> 0 is both senses
>> Modified: MOAB/trunk/src/io/ReadCGM.cpp
>> --- MOAB/trunk/src/io/ReadCGM.cpp 2011-03-30 22:46:58 UTC (rev 4695)
>> +++ MOAB/trunk/src/io/ReadCGM.cpp 2011-03-31 02:58:48 UTC (rev 4696)
>> @@ -273,12 +273,12 @@
>> if (forward) {
>> - rval = myGeomTool->set_sense( ci->second, entmap[3][forward], true
>> + rval = myGeomTool->set_sense( ci->second, entmap[3][forward], 1 );
>> if (MB_SUCCESS != rval)
>> return rval;
>> if (reverse) {
>> - rval = myGeomTool->set_sense( ci->second, entmap[3][reverse], false
>> + rval = myGeomTool->set_sense( ci->second, entmap[3][reverse], -1 );
>> return rval;
>> @@ -298,12 +298,12 @@
>> if (ce->get_sense() == CUBIT_UNKNOWN ||
>> ce->get_sense() != edge->get_curve_ptr()->bridge_sense()) {
>> ents.push_back(face);
>> - senses.push_back(CUBIT_REVERSED);
>> + senses.push_back(-1);
>> ce->get_sense() == edge->get_curve_ptr()->bridge_sense()) {
>> - senses.push_back(CUBIT_FORWARD);
>> + senses.push_back(1);
