[MOAB-dev] r4645 - in MOAB/trunk: examples src src/moab tools
    Tim Tautges
    tautges at mcs.anl.gov
    Wed Mar 30 17:01:52 CDT 2011
Yeah, that's exactly where the problem will be.  Iulian might be out for a few days, but it shouldn't be too long before
this is looked at.  How urgent is this, can you roll back your version and make due?
- tim
On 03/30/2011 03:54 PM, Steve Jackson wrote:
> An update to what I wrote before: r4645 passes read_cgm_test unit test, which loads the file 'dum.sat' that's included in MOAB.  This problem wasn't noticed earlier because this test was succeeding.
> It seems like the error might have to do with merged surfaces.  Running the commands below in Cubit 12.2 will convert dum.sat (currently readable by MOAB) to a file that is unreadable (i.e. ReadCGM returns MB_MULTIPLE_ENTITIES_FOUND).
> ~S
> set attrib on
> import acis 'dum.sat'
> imprint all
> merge all
> set geom version 1600
> export acis 'output.sat' overwrite
> On Mar 30, 2011, at 15:13 , Steve Jackson wrote:
>> r4645 breaks ReadCGM.  ReadCGM now returns MB_MULTIPLE_ENTITIES_FOUND for any .sat file I give it, including those that worked in previous revisions.  I haven't had time to investigate the details yet.  Iulian: do you have an idea of what might be going wrong?
>> ~S
>> On Mar 25, 2011, at 10:54 , iulian at mcs.anl.gov wrote:
>>> Author: iulian
>>> Date: 2011-03-25 10:54:42 -0500 (Fri, 25 Mar 2011)
>>> New Revision: 4645
>>> Modified:
>>>   MOAB/trunk/examples/GeomSetHierarchy.cpp
>>>   MOAB/trunk/src/GeomTopoTool.cpp
>>>   MOAB/trunk/src/moab/GeomTopoTool.hpp
>>>   MOAB/trunk/src/moab/Types.hpp
>>>   MOAB/trunk/tools/gsets.cc
>>> Log:
>>> sense tags modifications; some cleanup required
>>> meshkit tests do not pass now (test_scdmesh,
>>> test_copygeom,
>>> FAIL: test_triadvance
>>> FAIL: test_mbgeom
>>> FAIL: test_paver
>>> FAIL: test_tetmesher
>>> Old methods for senses are commented out, they will be completely removed
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
