[MOAB-dev] r4645 - in MOAB/trunk: examples src src/moab tools
    Steve Jackson
    sjackson at cae.wisc.edu
    Wed Mar 30 15:54:07 CDT 2011
An update to what I wrote before: r4645 passes read_cgm_test unit test, which loads the file 'dum.sat' that's included in MOAB.  This problem wasn't noticed earlier because this test was succeeding.
It seems like the error might have to do with merged surfaces.  Running the commands below in Cubit 12.2 will convert dum.sat (currently readable by MOAB) to a file that is unreadable (i.e. ReadCGM returns MB_MULTIPLE_ENTITIES_FOUND).
~S
set attrib on
import acis 'dum.sat'
imprint all
merge all
set geom version 1600
export acis 'output.sat' overwrite
On Mar 30, 2011, at 15:13 , Steve Jackson wrote:
> r4645 breaks ReadCGM.  ReadCGM now returns MB_MULTIPLE_ENTITIES_FOUND for any .sat file I give it, including those that worked in previous revisions.  I haven't had time to investigate the details yet.  Iulian: do you have an idea of what might be going wrong?
> ~S
> On Mar 25, 2011, at 10:54 , iulian at mcs.anl.gov wrote:
>> Author: iulian
>> Date: 2011-03-25 10:54:42 -0500 (Fri, 25 Mar 2011)
>> New Revision: 4645
>> Modified:
>>  MOAB/trunk/examples/GeomSetHierarchy.cpp
>>  MOAB/trunk/src/GeomTopoTool.cpp
>>  MOAB/trunk/src/moab/GeomTopoTool.hpp
>>  MOAB/trunk/src/moab/Types.hpp
>>  MOAB/trunk/tools/gsets.cc
>> Log:
>> sense tags modifications; some cleanup required
>> meshkit tests do not pass now (test_scdmesh,
>> test_copygeom,
>> FAIL: test_triadvance
>> FAIL: test_mbgeom
>> FAIL: test_paver
>> FAIL: test_tetmesher
>> Old methods for senses are commented out, they will be completely removed
