[MOAB-dev] exceptions & moab
Tim Tautges
tautges at mcs.anl.gov
Wed Mar 30 10:51:05 CDT 2011
For the fine-grained data objects (mesh entities, tag values), MOAB uses an array-based storage scheme, rather than a
C++ object-based scheme. So, exceptions in constructors aren't as much of an issue as they might be in other C++ mesh
databases.
ErrorCode has some information, and you can get more information by calling Interface::get_last_error.
All that said, we also recognize the need for better error handling, and there's a task in this year's plan for doing
that. Right now, that's as far as the planning has gone, though.
- tim
On 03/30/2011 10:39 AM, Xiabing Xu wrote:
> If you go to src/moab/Types.hpp, you could see the ErrorCode definition. I think it provides more information than
> what C++ exception does. And these error codes are used as condition variables most of the time to deal with
> different situations, they are used a lot when reading a file. That's what I understand so far.
> Xiabing
> On Mar 30, 2011, at 10:23 AM, Jayesh Krishna wrote:
>> Tim, Why did you decide on using error codes instead of C++ exceptions in moab ? How are errors in constructors
>> handled in moab ? Any inputs are welcome.
>> Regards, Jayesh
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
