[MOAB-dev] r4614 - in MOAB/trunk/src/parallel: . moab
tautges at mcs.anl.gov tautges at mcs.anl.gov
Fri Mar 18 21:38:42 CDT 2011
Author: tautges
Date: 2011-03-18 21:38:42 -0500 (Fri, 18 Mar 2011)
New Revision: 4614
Modified:
   MOAB/trunk/src/parallel/ParallelComm.cpp
   MOAB/trunk/src/parallel/moab/ParallelComm.hpp
Log:
Making sharedEnts a std::vector instead of a range.
Passes make check and separate mbconvert test.
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp	2011-03-18 23:45:20 UTC (rev 4613)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp	2011-03-19 02:38:42 UTC (rev 4614)
@@ -2057,12 +2057,14 @@
 ErrorCode ParallelComm::list_entities(const EntityHandle *ents, int num_ents)
   if (NULL == ents && 0 == num_ents) {
-    sharedEnts.print("Shared entities:\n");
+    Range shared_ents;
+    std::copy(sharedEnts.begin(), sharedEnts.end(), range_inserter(shared_ents));
+    shared_ents.print("Shared entities:\n");
     return MB_SUCCESS;
   else if (NULL == ents && 0 != num_ents) {
-    return list_entities(sharedEnts);
+    return list_entities(&sharedEnts[0], sharedEnts.size());
   unsigned char pstat;
@@ -2287,7 +2289,7 @@
   result = mbImpl->tag_set_data(pstatus_tag(), &new_h, 1, &pstat);
   RRA("Couldn't set pstatus tag.");
-  if (pstat & PSTATUS_SHARED) sharedEnts.insert(new_h);
+  if (pstat & PSTATUS_SHARED) sharedEnts.push_back(new_h);
   return MB_SUCCESS;
@@ -3683,15 +3685,15 @@
   ErrorCode result;
   int nprocs;
-  for (Range::iterator rit = sharedEnts.begin(); rit != sharedEnts.end(); rit++) {
-    if (shared_dim != -1 && mbImpl->dimension_from_handle(*rit) > shared_dim)
+  for (std::vector<EntityHandle>::iterator vit = sharedEnts.begin(); vit != sharedEnts.end(); vit++) {
+    if (shared_dim != -1 && mbImpl->dimension_from_handle(*vit) > shared_dim)
       continue;
-    result = get_sharing_data(*rit, procs, handles, pstat, nprocs);
+    result = get_sharing_data(*vit, procs, handles, pstat, nprocs);
     RRA("");
     std::sort(procs, procs+nprocs);
     std::vector<int> tmp_procs(procs, procs + nprocs);
     assert(tmp_procs.size() != 2);
-    proc_nvecs[tmp_procs].push_back(*rit);
+    proc_nvecs[tmp_procs].push_back(*vit);
   Skinner skinner(mbImpl);
@@ -3977,7 +3979,7 @@
