[MOAB-dev] r4613 - MOAB/trunk/src/parallel
Tim Tautges
tautges at mcs.anl.gov
Fri Mar 18 20:04:58 CDT 2011
Thanks!
- tim
On 03/18/2011 06:45 PM, hongjun at mcs.anl.gov wrote:
> Author: hongjun
> Date: 2011-03-18 18:45:20 -0500 (Fri, 18 Mar 2011)
> New Revision: 4613
> Modified:
> MOAB/trunk/src/parallel/ParallelComm.cpp
> Log:
> o Non-assigned "skin_dim" variable is set as "resolve_dim-1"
> o This commit is for "resolve_shared_ents" function giving "skin_ents" arrary by user
> o Passes "make check"
> Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
> --- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-03-18 22:37:32 UTC (rev 4612)
> +++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-03-18 23:45:20 UTC (rev 4613)
> @@ -3259,7 +3259,7 @@
> ErrorCode result;
> std::vector<int> gid_data;
> std::vector<EntityHandle> handle_vec;
> - int skin_dim;
> + int skin_dim = resolve_dim-1;
> // global id tag
> Tag gid_tag; int def_val = -1;
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
