[MOAB-dev] r4586 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu
Mon Mar 14 16:35:25 CDT 2011
Author: kraftche
Date: 2011-03-14 16:35:25 -0500 (Mon, 14 Mar 2011)
New Revision: 4586
Modified:
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
Log:
fix build issue with IBM compiler
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2011-03-14 21:17:30 UTC (rev 4585)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2011-03-14 21:35:25 UTC (rev 4586)
@@ -467,7 +467,7 @@
char name[sizeof(unsigned long)];
static size_t len( int name_len ) {
- return sizeof(serial_tag_data) + name_len - sizeof(name);
+ return sizeof(serial_tag_data) + name_len - sizeof(unsigned long);
size_t len() const { return len( name_len ); }
