[MOAB-dev] r4585 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu
Mon Mar 14 16:17:31 CDT 2011
Author: kraftche
Date: 2011-03-14 16:17:30 -0500 (Mon, 14 Mar 2011)
New Revision: 4585
Modified:
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
Log:
o Make parallel HDF5 write consistent with serial with regards to choosing
which tag data is to be written in the dense format.
o Fix bug in parallel HDF5 write where space is reserved in the sparse
dataset(s) for tag data that is written in the dense format.
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2011-03-12 00:23:59 UTC (rev 4584)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2011-03-14 21:17:30 UTC (rev 4585)
@@ -464,12 +464,10 @@
DataType type;
int size;
int name_len;
- unsigned long num_sparse_ents;
- unsigned long num_sparse_vals; // not used for fixed-length tags
char name[sizeof(unsigned long)];
static size_t len( int name_len ) {
- return sizeof(serial_tag_data) + name_len - sizeof(size_t);
+ return sizeof(serial_tag_data) + name_len - sizeof(name);
size_t len() const { return len( name_len ); }
@@ -508,15 +506,6 @@
return error(rval);
ptr->name_len = name_len;
Range range;
- rval = get_sparse_tagged_entities( tag, range );
- if (MB_SUCCESS != rval) return error(rval);
- ptr->num_sparse_ents = range.size();
- ptr->num_sparse_vals = 0;
- if (MB_VARIABLE_LENGTH == ptr->size) {
- rval = get_tag_data_length( tag, range, ptr->num_sparse_vals );
- assert(MB_SUCCESS == rval);
memset( ptr->name, 0, ptr->name_len );
memcpy( ptr->name, name.data(), name.size() );
@@ -544,7 +533,6 @@
ErrorCode rval;
int err;
const int num_proc = myPcomm->proc_config().proc_size();
- int num_tags = tagList.size();
dbgOut.tprint(1,"communicating tag metadata\n");
@@ -561,9 +549,9 @@
return error(rval);
- dbgOut.printf(2,"Exchanging tag data for %d tags.\n", num_tags);
+ dbgOut.printf(2,"Exchanging tag data for %d tags.\n", (int)tagList.size() );
- // Exchange tag data between all processors
+ // Exchange tag descriptions between all processors
