[MOAB-dev] buildbot failure in Fathom on moab-serial
    moab-dev at mcs.anl.gov
    Mon Mar 14 00:02:52 CDT 2011
The Fathomatic has detected a failed build of moab-serial on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-serial/builds/446
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
[0;32mPASS[m: MOAB_iMesh_unit_tests
[0;32m==================
All 2 tests passed
[mmake[6]: Leaving directory `/disks/itaps-buildslave/moab-serial/build/itaps/imesh'
make[3]: Entering directory `/disks/itaps-buildslave/moab-serial/build/itaps'
make[3]: Nothing to be done for `check-am'.
Making check in tools
make[2]: Entering directory `/disks/itaps-buildslave/moab-serial/build/tools'
Making check in .
make[3]: Entering directory `/disks/itaps-buildslave/moab-serial/build/tools'
make  test_prog_opt
make[4]: Entering directory `/disks/itaps-buildslave/moab-serial/build/tools'
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I../test -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DNETCDF_FILE -I../src -I../src -I../src/parallel -I../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT test_prog_opt-test_prog_opt.o -MD -MP -MF .deps/test_prog_opt-test_prog_opt.Tpo -c -o test_prog_opt-test_prog_opt.o `test -f 'test_prog_opt.cpp' || echo './'`test_prog_opt.cpp
mv -f .deps/test_prog_opt-test_prog_opt.Tpo .deps/test_prog_opt-test_prog_opt.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o test_prog_opt test_prog_opt-test_prog_opt.o libprogram_opt.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o test_prog_opt test_prog_opt-test_prog_opt.o  ./.libs/libprogram_opt.a -lm
make  check-TESTS
make[5]: Entering directory `/disks/itaps-buildslave/moab-serial/build/tools'
[0;32mPASS[m: test_prog_opt
[0;32m=============
1 test passed
[mmake[5]: Leaving directory `/disks/itaps-buildslave/moab-serial/build/tools'
Making check in dagmc
make[3]: Entering directory `/disks/itaps-buildslave/moab-serial/build/tools/dagmc'
make  test_geom pt_vol_test ray_fire_test
make[4]: Entering directory `/disks/itaps-buildslave/moab-serial/build/tools/dagmc'
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DNETCDF_FILE -I../../src -I../../src -I../../tools  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT test_geom.o -MD -MP -MF .deps/test_geom.Tpo -c -o test_geom.o test_geom.cc
mv -f .deps/test_geom.Tpo .deps/test_geom.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o test_geom test_geom.o libdagmc.la ../../src/libMOAB.la    -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o test_geom test_geom.o  ./.libs/libdagmc.a ../../src/.libs/libMOAB.a -lnetcdf -lm
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DNETCDF_FILE -I../../src -I../../src -I../../tools  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT pt_vol_test.o -MD -MP -MF .deps/pt_vol_test.Tpo -c -o pt_vol_test.o pt_vol_test.cc
mv -f .deps/pt_vol_test.Tpo .deps/pt_vol_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o pt_vol_test pt_vol_test.o libdagmc.la ../../src/libMOAB.la    -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o pt_vol_test pt_vol_test.o  ./.libs/libdagmc.a ../../src/.libs/libMOAB.a -lnetcdf -lm
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DNETCDF_FILE -I../../src -I../../src -I../../tools  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ray_fire_test.o -MD -MP -MF .deps/ray_fire_test.Tpo -c -o ray_fire_test.o ray_fire_test.cc
mv -f .deps/ray_fire_test.Tpo .deps/ray_fire_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o ray_fire_test ray_fire_test.o libdagmc.la ../../src/libMOAB.la    -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o ray_fire_test ray_fire_test.o  ./.libs/libdagmc.a ../../src/.libs/libMOAB.a -lnetcdf -lm
make  check-TESTS
make[5]: Entering directory `/disks/itaps-buildslave/moab-serial/build/tools/dagmc'
[0;31mFAIL[m: test_geom
[0;31m==============================
1 of 1 test failed
See tools/dagmc/test-suite.log
[mmake[5]: *** [test-suite.log] Error 1
sincerely,
 -The Fathomatic
