[MOAB-dev] buildbot failure in Fathom on moab-4.0-distcheck
    moab-dev at mcs.anl.gov
    Sun Mar 13 00:16:28 CST 2011
The Fathomatic has detected a failed build of moab-4.0-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-4.0-distcheck/builds/97
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
make[6]: Entering directory `/disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/itaps/imesh'
gcc -DHAVE_CONFIG_H -I. -I../../../itaps/imesh -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DNETCDF_FILE -DSRCDIR=../../../itaps/imesh -I../../../itaps/imesh/.. -I../../../src -I../../src -I../../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT testc_cbind.o -MD -MP -MF .deps/testc_cbind.Tpo -c -o testc_cbind.o ../../../itaps/imesh/testc_cbind.c
mv -f .deps/testc_cbind.Tpo .deps/testc_cbind.Po
/bin/sh ../../libtool  --tag=CC   --mode=link gcc  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o testc_cbind testc_cbind.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/usr/lib/x86_64-linux-gnu -lstdc++ -lm
libtool: link: gcc -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o testc_cbind testc_cbind.o  ./.libs/libiMesh.a /disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/src/.libs/libMOAB.a ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/usr/lib/x86_64-linux-gnu -lstdc++ -lm
g++ -DHAVE_CONFIG_H -I. -I../../../itaps/imesh -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DNETCDF_FILE -DSRCDIR=../../../itaps/imesh -I../../../itaps/imesh/.. -I../../../src -I../../src -I../../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT MOAB_iMesh_unit_tests.o -MD -MP -MF .deps/MOAB_iMesh_unit_tests.Tpo -c -o MOAB_iMesh_unit_tests.o ../../../itaps/imesh/MOAB_iMesh_unit_tests.cpp
mv -f .deps/MOAB_iMesh_unit_tests.Tpo .deps/MOAB_iMesh_unit_tests.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o MOAB_iMesh_unit_tests MOAB_iMesh_unit_tests.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/usr/lib/x86_64-linux-gnu -lstdc++ -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o MOAB_iMesh_unit_tests MOAB_iMesh_unit_tests.o  ./.libs/libiMesh.a /disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/src/.libs/libMOAB.a ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/usr/lib/x86_64-linux-gnu -lstdc++ -lm
make  check-TESTS
make[7]: Entering directory `/disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/itaps/imesh'
[0;32mPASS[m: testc_cbind
[0;32mPASS[m: MOAB_iMesh_unit_tests
[0;32m==================
All 2 tests passed
[mmake[7]: Leaving directory `/disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/itaps/imesh'
make[4]: Entering directory `/disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/itaps'
make[4]: Nothing to be done for `check-am'.
Making check in tools
make[3]: Entering directory `/disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/tools'
Making check in .
make[4]: Entering directory `/disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/tools'
Making check in dagmc
make[4]: Entering directory `/disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/tools/dagmc'
make  test_geom pt_vol_test ray_fire_test
make[5]: Entering directory `/disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/tools/dagmc'
g++ -DHAVE_CONFIG_H -I. -I../../../tools/dagmc -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DNETCDF_FILE -I../../../src -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT test_geom.o -MD -MP -MF .deps/test_geom.Tpo -c -o test_geom.o ../../../tools/dagmc/test_geom.cc
mv -f .deps/test_geom.Tpo .deps/test_geom.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o test_geom test_geom.o libdagmc.la ../../src/libMOAB.la    -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o test_geom test_geom.o  ./.libs/libdagmc.a ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -lm
g++ -DHAVE_CONFIG_H -I. -I../../../tools/dagmc -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DNETCDF_FILE -I../../../src -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT pt_vol_test.o -MD -MP -MF .deps/pt_vol_test.Tpo -c -o pt_vol_test.o ../../../tools/dagmc/pt_vol_test.cc
mv -f .deps/pt_vol_test.Tpo .deps/pt_vol_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o pt_vol_test pt_vol_test.o libdagmc.la ../../src/libMOAB.la    -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o pt_vol_test pt_vol_test.o  ./.libs/libdagmc.a ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -lm
g++ -DHAVE_CONFIG_H -I. -I../../../tools/dagmc -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DNETCDF_FILE -I../../../src -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT ray_fire_test.o -MD -MP -MF .deps/ray_fire_test.Tpo -c -o ray_fire_test.o ../../../tools/dagmc/ray_fire_test.cc
mv -f .deps/ray_fire_test.Tpo .deps/ray_fire_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o ray_fire_test ray_fire_test.o libdagmc.la ../../src/libMOAB.la    -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o ray_fire_test ray_fire_test.o  ./.libs/libdagmc.a ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -lm
make  check-TESTS
make[6]: Entering directory `/disks/itaps-buildslave/moab-4.0-distcheck/build/moab-4.0.0/_build/tools/dagmc'
[0;31mFAIL[m: test_geom
[0;31m==============================
1 of 1 test failed
See tools/dagmc/test-suite.log
[mmake[6]: *** [test-suite.log] Error 1
sincerely,
 -The Fathomatic
