[MOAB-dev] r4581 - MOAB/trunk/src/io
jvporter at wisc.edu
Fri Mar 11 02:02:58 CST 2011
Author: jvporter
Date: 2011-03-11 02:02:57 -0600 (Fri, 11 Mar 2011)
New Revision: 4581
Modified:
MOAB/trunk/src/io/ReadNC.cpp
Log:
Fix a few warnings
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2011-03-11 07:46:15 UTC (rev 4580)
+++ MOAB/trunk/src/io/ReadNC.cpp 2011-03-11 08:02:57 UTC (rev 4581)
@@ -226,7 +226,6 @@
ScdInterface *scdi = NULL;
ErrorCode rval = mbImpl->query_interface(scdi);
if (!scdi) return MB_FAILURE;
- int num_verts = (ilMax - ilMin + 1) * (jlMax - jlMin + 1) * (-1 == klMin ? 1 : klMax-klMin+1);
Range tmp_range;
ScdBox *scd_box;
@@ -280,6 +279,8 @@
#ifndef NDEBUG
+ int num_verts = (ilMax - ilMin + 1) * (jlMax - jlMin + 1) *
+ (-1 == klMin ? 1 : klMax-klMin+1);
std::vector<int> gids(num_verts);
rval = mbImpl->tag_get_data(mGlobalIdTag, tmp_range, &gids[0]);
if (MB_SUCCESS != rval) mbImpl->release_interface(scdi);
@@ -499,24 +500,22 @@
case NC_DOUBLE:
case NC_FLOAT:
ddata = (double*)data;
- for (unsigned int i = 0; i < verts.size(); i++) {
- if (!i) dmin = ddata[i], dmax = ddata[i];
- else {
- if (ddata[i] < dmin) dmin = ddata[i];
- if (ddata[i] > dmax) dmax = ddata[i];
+ if (!verts.empty())
+ dmin = ddata[0], dmax = ddata[0];
+ for (unsigned int i = 1; i < verts.size(); i++) {
+ if (ddata[i] < dmin) dmin = ddata[i];
+ if (ddata[i] > dmax) dmax = ddata[i];
dbgOut.tprintf(2, "Variable %s (double): min = %f, max = %f\n", var_data.varName.c_str(), dmin, dmax);
break;
case NC_INT:
case NC_SHORT:
idata = (int*)data;
- if (!i) imin = idata[i], imax = idata[i];
- else {
- if (idata[i] < imin) imin = idata[i];
- if (idata[i] > imax) imax = idata[i];
+ imin = idata[0], imax = idata[0];
