[MOAB-dev] r4578 - MOAB/trunk/itaps/imesh
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Mar 10 18:44:48 CST 2011
Author: kraftche
Date: 2011-03-10 18:44:48 -0600 (Thu, 10 Mar 2011)
New Revision: 4578
Modified:
   MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
Log:
fix size returned via iMesh API for bit tags
Modified: MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
--- MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp	2011-03-10 22:38:23 UTC (rev 4577)
+++ MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp	2011-03-11 00:44:48 UTC (rev 4578)
@@ -1680,9 +1680,11 @@
       case MB_TYPE_HANDLE:
         *tag_size_val /= sizeof(EntityHandle);
         break;
-      case MB_TYPE_OPAQUE:
       case MB_TYPE_BIT:
+        *tag_size_val = 1;
         break;
+      case MB_TYPE_OPAQUE:
+        break;
     RETURN(iBase_SUCCESS);
@@ -1692,8 +1694,16 @@
                              /*in*/ const iBase_TagHandle tag_handle,
                              int *tag_size_bytes, int *err)
-    ErrorCode result = MOABI->tag_get_size(TAG_HANDLE(tag_handle), *tag_size_bytes);
-    CHKERR(result, "iMesh_getTagSize: problem getting size.");
+    DataType this_type;
+    ErrorCode result = MOABI->tag_get_data_type(TAG_HANDLE(tag_handle), this_type);
+    CHKERR(result, "iMesh_getTagSize: problem getting type.");
+    if (MB_TYPE_BIT == this_type)
+      *tag_size_bytes = 1;
+    else {
+      result = MOABI->tag_get_size(TAG_HANDLE(tag_handle), *tag_size_bytes);
+      CHKERR(result, "iMesh_getTagSize: problem getting size.");
