[MOAB-dev] buildbot failure in Fathom on moab-par
    moab-dev at mcs.anl.gov
    Tue Feb 22 00:06:20 CST 2011
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/430
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
mpiCC -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../src -I../src -I../src/parallel -I../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT propagate_tags.o -MD -MP -MF .deps/propagate_tags.Tpo -c -o propagate_tags.o propagate_tags.cpp
mv -f .deps/propagate_tags.Tpo .deps/propagate_tags.Po
/bin/sh ../libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -L/home/jvporter/packages/hdf5-x64-parallel/lib -L/home/jvporter/packages/hdf5-x64-parallel/lib   -L/home/jvporter/packages/hdf5-x64-parallel/lib -o mbtagprop parse.o propagate_tags.o ../src/libMOAB.la -lm
mpiCC -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o mbtagprop parse.o propagate_tags.o  -L/home/jvporter/packages/hdf5-x64-parallel/lib ../src/.libs/libMOAB.a -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
mpiCC -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../src -I../src -I../src/parallel -I../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT mbmem.o -MD -MP -MF .deps/mbmem.Tpo -c -o mbmem.o mbmem.cpp
mv -f .deps/mbmem.Tpo .deps/mbmem.Po
/bin/sh ../libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -L/home/jvporter/packages/hdf5-x64-parallel/lib -L/home/jvporter/packages/hdf5-x64-parallel/lib   -L/home/jvporter/packages/hdf5-x64-parallel/lib -o mbmem mbmem.o ../src/libMOAB.la -lm
mpiCC -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o mbmem mbmem.o  -L/home/jvporter/packages/hdf5-x64-parallel/lib ../src/.libs/libMOAB.a -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
mpiCC -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../src -I../src -I../src/parallel -I../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT SphereDecomp.o -MD -MP -MF .deps/SphereDecomp.Tpo -c -o SphereDecomp.o SphereDecomp.cpp
mv -f .deps/SphereDecomp.Tpo .deps/SphereDecomp.Po
mpiCC -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../src -I../src -I../src/parallel -I../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT sphere_decomp.o -MD -MP -MF .deps/sphere_decomp.Tpo -c -o sphere_decomp.o sphere_decomp.cpp
mv -f .deps/sphere_decomp.Tpo .deps/sphere_decomp.Po
/bin/sh ../libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -L/home/jvporter/packages/hdf5-x64-parallel/lib -L/home/jvporter/packages/hdf5-x64-parallel/lib   -L/home/jvporter/packages/hdf5-x64-parallel/lib -o spheredecomp SphereDecomp.o sphere_decomp.o ../src/libMOAB.la -lm
mpiCC -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o spheredecomp SphereDecomp.o sphere_decomp.o  -L/home/jvporter/packages/hdf5-x64-parallel/lib ../src/.libs/libMOAB.a -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
mpiCC -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../src -I../src -I../src/parallel -I../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT surfplot.o -MD -MP -MF .deps/surfplot.Tpo -c -o surfplot.o surfplot.cpp
mv -f .deps/surfplot.Tpo .deps/surfplot.Po
/bin/sh ../libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -L/home/jvporter/packages/hdf5-x64-parallel/lib -L/home/jvporter/packages/hdf5-x64-parallel/lib   -L/home/jvporter/packages/hdf5-x64-parallel/lib -o mbsurfplot surfplot.o ../src/libMOAB.la -lm
mpiCC -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o mbsurfplot surfplot.o  -L/home/jvporter/packages/hdf5-x64-parallel/lib ../src/.libs/libMOAB.a -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
mpiCC -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../src -I../src -I../src/parallel -I../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT gsets.o -MD -MP -MF .deps/gsets.Tpo -c -o gsets.o gsets.cc
mv -f .deps/gsets.Tpo .deps/gsets.Po
/bin/sh ../libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -L/home/jvporter/packages/hdf5-x64-parallel/lib -L/home/jvporter/packages/hdf5-x64-parallel/lib   -L/home/jvporter/packages/hdf5-x64-parallel/lib -o mbgsets gsets.o ../src/libMOAB.la -lm
mpiCC -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o mbgsets gsets.o  -L/home/jvporter/packages/hdf5-x64-parallel/lib ../src/.libs/libMOAB.a -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
mpiCC -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../src -I../src -I../src/parallel -I../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT parread.o -MD -MP -MF .deps/parread.Tpo -c -o parread.o parread.cpp
mv -f .deps/parread.Tpo .deps/parread.Po
/bin/sh ../libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -L/home/jvporter/packages/hdf5-x64-parallel/lib -L/home/jvporter/packages/hdf5-x64-parallel/lib   -L/home/jvporter/packages/hdf5-x64-parallel/lib -o parread parread.o ../src/libMOAB.la -lm
mpiCC -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o parread parread.o  -L/home/jvporter/packages/hdf5-x64-parallel/lib ../src/.libs/libMOAB.a -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
Making all in dagmc
make[4]: Entering directory `/disk/itaps-buildslave/moab-par/build/tools/dagmc'
/bin/sh ../../libtool --tag=CXX   --mode=compile mpiCC -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../../src -I../../src -I../../tools  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT DagMC.lo -MD -MP -MF .deps/DagMC.Tpo -c -o DagMC.lo DagMC.cpp
 mpiCC -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../../src -I../../src -I../../tools -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT DagMC.lo -MD -MP -MF .deps/DagMC.Tpo -c DagMC.cpp -o DagMC.o
mv -f .deps/DagMC.Tpo .deps/DagMC.Plo
/bin/sh ../../libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -L/home/jvporter/packages/hdf5-x64-parallel/lib -L/home/jvporter/packages/hdf5-x64-parallel/lib   -L/home/jvporter/packages/hdf5-x64-parallel/lib -o libdagmc.la -rpath /usr/local/lib DagMC.lo  -lm
mkdir .libs
ar cru .libs/libdagmc.a  DagMC.o
ranlib .libs/libdagmc.a
creating libdagmc.la
(cd .libs && rm -f libdagmc.la && ln -s ../libdagmc.la libdagmc.la)
mpiCC -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../../src -I../../src -I../../tools  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT dagmc_preproc.o -MD -MP -MF .deps/dagmc_preproc.Tpo -c -o dagmc_preproc.o dagmc_preproc.cpp
mv -f .deps/dagmc_preproc.Tpo .deps/dagmc_preproc.Po
/bin/sh ../../libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -L/home/jvporter/packages/hdf5-x64-parallel/lib -L/home/jvporter/packages/hdf5-x64-parallel/lib   -L/home/jvporter/packages/hdf5-x64-parallel/lib -o dagmc_preproc dagmc_preproc.o libdagmc.la ../../src/libMOAB.la    ../libprogram_opt.la -lm
mpiCC -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o dagmc_preproc dagmc_preproc.o  -L/home/jvporter/packages/hdf5-x64-parallel/lib ./.libs/libdagmc.a ../../src/.libs/libMOAB.a -lnetcdf /homes/jvporter/lib/libhdf5.a -lz ../.libs/libprogram_opt.a -lm
mpiCC -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../../src -I../../src -I../../tools  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT quads_to_tris_driver.o -MD -MP -MF .deps/quads_to_tris_driver.Tpo -c -o quads_to_tris_driver.o quads_to_tris_driver.cpp
mv -f .deps/quads_to_tris_driver.Tpo .deps/quads_to_tris_driver.Po
mpiCC -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/home/jvporter/packages/hdf5-x64-parallel/include -isystem /home/jvporter/packages/hdf5-x64-parallel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../../src -I../../src -I../../tools  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT quads_to_tris.o -MD -MP -MF .deps/quads_to_tris.Tpo -c -o quads_to_tris.o quads_to_tris.cpp
mv -f .deps/quads_to_tris.Tpo .deps/quads_to_tris.Po
/bin/sh ../../libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -L/home/jvporter/packages/hdf5-x64-parallel/lib -L/home/jvporter/packages/hdf5-x64-parallel/lib   -L/home/jvporter/packages/hdf5-x64-parallel/lib -o quads_to_tris quads_to_tris_driver.o quads_to_tris.o ../../src/libMOAB.la -lm
mpiCC -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o quads_to_tris quads_to_tris_driver.o quads_to_tris.o  -L/home/jvporter/packages/hdf5-x64-parallel/lib ../../src/.libs/libMOAB.a -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
Making all in mbfacetgeom
make[4]: Entering directory `/disk/itaps-buildslave/moab-par/build/tools/mbfacetgeom'
make[4]: *** No rule to make target `Makefile.am', needed by `Makefile.in'.  Stop.
sincerely,
 -The Fathomatic
