[MOAB-dev] Performance regressions in MOAB
James Porter
jvporter at wisc.edu
Mon Feb 21 13:55:08 CST 2011
On Mon, 2011-02-21 at 10:03 -0600, Jason Kraftcheck wrote:
> Are you creating and destroying many MOAB instances? If so, then the
> culprit is likely time time spent initializing the memory allocated for the
> SequenceDatas. If that is the case, then we could rearrange things such
> that the memory isn't initialized unless the corresponding entities are
> allocated. But I don't know that it is worth the time for what is an
> unlikely use case.
Ah, that'll do it. The Python tests create a MOAB instance for every
test that they run. I suppose I could modify the tests, since this isn't
strictly necessary in most of them.
> The most memory use I see when doing "make check" for MOAB is exodus_test
> consuming 3 MB.
Odd. Maybe it's something else...
- Jim
