[MOAB-dev] buildbot failure in Fathom on moab-distcheck
moab-dev at mcs.anl.gov moab-dev at mcs.anl.gov
Thu Feb 17 01:15:48 CST 2011
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/414
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed failed slave lost
LOG EXCERPT:
../../../tools/mbfacetgeom/mbfacet_test.cpp:377: warning: comparison between signed and unsigned integer expressions
mv -f .deps/mbfacet_test.Tpo .deps/mbfacet_test.Po
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o facet_test mbfacet_test.o libmbfacetgeom.la -lm
g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o facet_test mbfacet_test.o  ./.libs/libmbfacetgeom.a /disk/itaps-buildslave/moab-distcheck/build/moab-4.99/_build/src/.libs/libMOAB.a -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
make  check-TESTS
make[5]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/_build/tools/mbfacetgeom'
Using default input file: ../../../MeshFiles/unittest/PB.h5m
root set test: Success
gentity set test: Success
geometry evals test: Success
normal evals test: Success
ray test: Failed to get entity type.
ERROR: Failed to get bounding box of entity.
  Error code: 15
  At        : ../../../tools/mbfacetgeom/mbfacet_test.cpp:360
Failure
PASS: facet_test
All 1 tests passed
Making check in test
make[3]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/_build/test'
Making check in .
make[4]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/_build/test'
make  moab_test homxform_test scdseq_test test_adj seq_man_test geom_util_test xform_test obb_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test mbcn_test bsp_tree_poly_test kd_tree_tool kd_tree_time
make[5]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/_build/test'
g++ -DHAVE_CONFIG_H -I. -I../../test -I.. -I../src/moab -I../src/parallel -I../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=../../test -DMESHDIR=../../MeshFiles/unittest -I../src -I../../src -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT MBTest.o -MD -MP -MF .deps/MBTest.Tpo -c -o MBTest.o ../../test/MBTest.cpp
mv -f .deps/MBTest.Tpo .deps/MBTest.Po
gunzip -c ../../MeshFiles/unittest/mb_big_test.g.gz > mb_big_test.g
gunzip -c ../../MeshFiles/unittest/cell1.gen.gz > cell1.gen
gunzip -c ../../MeshFiles/unittest/cell2.gen.gz > cell2.gen
/bin/sh ../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o moab_test MBTest.o ../src/libMOAB.la -lm
mkdir .libs
g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o moab_test MBTest.o  ../src/.libs/libMOAB.a -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
g++ -DHAVE_CONFIG_H -I. -I../../test -I.. -I../src/moab -I../src/parallel -I../src  -DTEST -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=../../test -DMESHDIR=../../MeshFiles/unittest -I../src -I../../src -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT homxform_test-HomXform.o -MD -MP -MF .deps/homxform_test-HomXform.Tpo -c -o homxform_test-HomXform.o `test -f '../../src/HomXform.cpp' || echo '../../test/'`../../src/HomXform.cpp
mv -f .deps/homxform_test-HomXform.Tpo .deps/homxform_test-HomXform.Po
/bin/sh ../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o homxform_test homxform_test-HomXform.o ../src/libMOAB.la -lm
g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o homxform_test homxform_test-HomXform.o  ../src/.libs/libMOAB.a -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
g++ -DHAVE_CONFIG_H -I. -I../../test -I.. -I../src/moab -I../src/parallel -I../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=../../test -DMESHDIR=../../MeshFiles/unittest -I../src -I../../src -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT scdseq_test.o -MD -MP -MF .deps/scdseq_test.Tpo -c -o scdseq_test.o ../../test/scdseq_test.cpp
../../test/scdseq_test.cpp: In function 'int main(int, char**)':
../../test/scdseq_test.cpp:266: warning: dereferencing type-punned pointer will break strict-aliasing rules
mv -f .deps/scdseq_test.Tpo .deps/scdseq_test.Po
/bin/sh ../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o scdseq_test scdseq_test.o ../src/libMOAB.la -lm
g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o scdseq_test scdseq_test.o  ../src/.libs/libMOAB.a -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
g++ -DHAVE_CONFIG_H -I. -I../../test -I.. -I../src/moab -I../src/parallel -I../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=../../test -DMESHDIR=../../MeshFiles/unittest -I../src -I../../src -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT test_adj.o -MD -MP -MF .deps/test_adj.Tpo -c -o test_adj.o ../../test/test_adj.cpp
mv -f .deps/test_adj.Tpo .deps/test_adj.Po
/bin/sh ../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o test_adj test_adj.o ../src/libMOAB.la -lm
g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o test_adj test_adj.o  ../src/.libs/libMOAB.a -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
g++ -DHAVE_CONFIG_H -I. -I../../test -I.. -I../src/moab -I../src/parallel -I../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=../../test -DMESHDIR=../../MeshFiles/unittest -I../src -I../../src -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT TestTypeSequenceManager.o -MD -MP -MF .deps/TestTypeSequenceManager.Tpo -c -o TestTypeSequenceManager.o ../../test/TestTypeSequenceManager.cpp
mv -f .deps/TestTypeSequenceManager.Tpo .deps/TestTypeSequenceManager.Po
sincerely,
 -The Fathomatic
