[MOAB-dev] r4499 - in MOAB/branches/Version4.0: . config
kraftche at cae.wisc.edu
Wed Feb 16 10:03:46 CST 2011
Author: kraftche
Date: 2011-02-16 10:03:46 -0600 (Wed, 16 Feb 2011)
New Revision: 4499
Modified:
MOAB/branches/Version4.0/RELEASE_NOTES
MOAB/branches/Version4.0/config/netcdf.m4
Log:
Fix netcdf build w/ required HDF5 in non-system path
Modified: MOAB/branches/Version4.0/RELEASE_NOTES
--- MOAB/branches/Version4.0/RELEASE_NOTES 2011-02-16 15:52:48 UTC (rev 4498)
+++ MOAB/branches/Version4.0/RELEASE_NOTES 2011-02-16 16:03:46 UTC (rev 4499)
@@ -1,5 +1,6 @@
Version 4.0.1:
* Fix zoltan build on case-insensitive file systems (e.g. MacOS)
+* Fix netcdf build w/ required HDF5 in non-system path
Version 4.0:
* Many improvements to parallel correctness and efficiency
Modified: MOAB/branches/Version4.0/config/netcdf.m4
--- MOAB/branches/Version4.0/config/netcdf.m4 2011-02-16 15:52:48 UTC (rev 4498)
+++ MOAB/branches/Version4.0/config/netcdf.m4 2011-02-16 16:03:46 UTC (rev 4499)
@@ -116,6 +116,8 @@
[AC_MSG_RESULT([yes]); NETCDF_LIBS="-lnetcdf_c++ -lnetcdf"],
[AC_MSG_RESULT([no]);
AC_MSG_CHECKING([for netcdf_c++ library requiring HDF5-high-level])
+ LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
+ NETCDF_LDFLAGS="$NETCDF_LDFLAGS $HDF5_LDFLAGS"
LIBS="$LIBS $HDF5_LIBS -lhdf5_hl -lhdf5"
AC_TRY_LINK(
[#include <netcdf.hh>], [NcFile ncf("foo",NcFile::ReadOnly);],
